Engine Build Pics - CAR ON THE ROAD
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
Chrenan
PostPosted: Tue May 30, 2006 11:55 pm    Post subject: Reply with quote
Meneer aard wrote:
Did you first clean your engine bay before you put the engine in the car?
I gave it a quick wipe, but nothing major, it's not a show car.
Mike924
PostPosted: Wed May 31, 2006 4:41 pm    Post subject: Reply with quote
This is a different car to the yellow one in your avatar, right?
Are you going to keep both going or is this one to be a replacement?
Chrenan
PostPosted: Fri Jun 02, 2006 12:23 pm    Post subject: Reply with quote
Same car as in the avatar, the engine bay is the original colour, which I hope to return the car to eventually.
Mike924
PostPosted: Fri Jun 02, 2006 4:43 pm    Post subject: Reply with quote
Oh right - I can just see a bit of yellow in the top corner of the picture.
It should look pretty wicked in black.
Chrenan
PostPosted: Wed Jun 14, 2006 12:34 am    Post subject: Reply with quote
OK, I had the car on the road for the first time with the new engine last night. Just as a reminder of the general modifications over stock:
Euro Race "Big Valve" head
Stage 1 cam (mild profile, one step up in agressiveness from stock)
Euro pistons (9.3:1)
Audi 5000 throttle body
Cat delete
In addition to this, all other items that touch the engine are new except for the alternator (i.e., starter, clutch, mounts, etc etc).
Setting the ignition timing was a real pain. I seem to remember with my old engine, the range of twist on the distributor where the engine would run OK was pretty large. With this setup, I had to adjust it over and over, the range where the engine would run OK was tiny, and the "sweet spot" was really that, one spot. Finally got it and it ran amazing. The idle sounds amazing, a really nice burble, a little lumpier than before. On the run, the car is noticeably quicker, very smooth at higher rpm (likely from not having a broken exhaust side mount), just feels great all round, I am very happy with the improvement. Oil pressure and temperature were good at idle and on the run, no fuel, oil or coolant leaks that I could see during tuning or after shutdown. Got out for a drive for an hour, ran up and down the gears the whole time, lots of acceleration and deceleration (in gear) for the whole time.
Now for the bad news, I think I need to adjust my clutch, please see this thread:
http://www.924board.org/viewtopic.php?p=156547#156547
Stampedetrail
PostPosted: Wed Jun 14, 2006 10:57 am    Post subject: Reply with quote
SWEET! you must be giddy as a schoolgirl, I know I would be.
1977.5 924 "Martini" head / New Old Stock rebuild
1985.5 944 Why? Because I can.
PostPosted: Thu Jun 15, 2006 9:56 am    Post subject: Reply with quote
Way to go ..
My924gtc
PostPosted: Thu Jun 15, 2006 12:44 pm    Post subject: Reply with quote
Chrenan wrote:
Hmmm, never noticed that before. That must be wrong, according to the housebrown thread from a few months ago, you can't produce and profit (even slightly) from an adjustable timing gear at less than something like $300.
Excellent looking engine build, glad it is working out for you and all but the prior discussion you are referring to was about variable cam gears, not adjustable, big difference.
I agree with some others that a header, and an aluminum flywheel would have been nice touches, but so would other things if you were going for more power.
Congrats are in order.
MJ
'81 924 2.0L T
'82 924 2.3L SC/EFI <---online fall '06
Sponsor of the 944 Cup and Super Cup
Sponsor of the "2006 Battle in the Badlands"
Chrenan
PostPosted: Thu Jun 15, 2006 11:54 pm    Post subject: Reply with quote
Ahh, that makes much more sense, variable timing gear, not adjustable, my mistake.
Yeah, I certainly didn't go as extreme as I could have, but it hopefully won't be my last 924 build up, so I plan on going a little farther on the next one, not up to the mad scientist super charger / turbo stuff that you guys do, but maybe a little more (stroker, lightened flywheel, EFI, etc.).
Page 9 of 9
