Audi in a porsche
Keaton
PostPosted: Fri Mar 17, 2006 6:45 pm    Post subject: Audi in a porsche Reply with quote
ok so i have looked through the engine trasplants looking for Audi V6's and really didnt fint any thing useful. So i found a factor rebuild Audi V6 with a 90k mile warrenty 2.8L 12 valve for $500, then add in a Megasquirt EFI kit and drop it in my car.
i know i'll need to make motor mounts and oil pan and oil pick up
so the question is:
1) will it fit?
2) bellhousing, will it bolt up or do i need to coustomize it?
3) should i quit dreaming and go with what i have in the car
Khal
PostPosted: Fri Mar 17, 2006 6:49 pm    Post subject: Reply with quote
Y'now we have a forum for this...
'80 924 Turbo
Ozzie
PostPosted: Fri Mar 17, 2006 6:52 pm    Post subject: Reply with quote
You can make just about anything fit in the car providing you have the time, patience and $$$$.
I have seen them with a v6 3.8lt advertised here in Oz.
Don't know how he did it but I can assume engine mounts, bellhousing and drive train were all modified.
Engine computer and management system, wiring, exhaust, cooling etc would have to be specially fitted.
More mods than the cars value.
Its AUTO and its BLACK
Montego Black on black/red
hausbrauen
PostPosted: Fri Mar 17, 2006 11:16 pm    Post subject: Re: Audi in a porsche Reply with quote
so the question is:
1) will it fit?
What car?
Sid
S2 931
CFO Hausbrauen Motoren
'06 Sponsors of the 944 Cup and SuperCup
timstar92404
PostPosted: Fri Mar 17, 2006 11:25 pm    Post subject: Reply with quote
I think if you're going to go through the trouble of doing an engine transplant at least put a v8 in it
and yeah if you have the cash you can do anything, I saw a pic of some guy with a 944 with a 911 flat six
78 924 sold.
85.5 944
chris24
PostPosted: Sat Mar 18, 2006 2:31 am    Post subject: Reply with quote
I thought that the flat 6 didn't fit?
1983 - 924 (185K miles) - not mint
1985 - 924 (148K miles) - mint
1990 - 944S2 cab (52K miles)
PostPosted: Sat Mar 18, 2006 6:17 am    Post subject: Reply with quote
flat-6 wtf? where? show me
Keaton
PostPosted: Sat Mar 18, 2006 7:01 am    Post subject: Reply with quote
all th V8 that i've seen in a 924, they have the hoods cut. if i did a motor swap i want it so you cant tell. every thing needs to fit under the hood.
chris24
PostPosted: Sat Mar 18, 2006 7:20 am    Post subject: Reply with quote
There's a nice rover V8 conversion that's been done over here. It was for sale a while ago. I've seen it. Looks like a standard 924 and goes like crazy.
timstar92404
PostPosted: Sat Mar 18, 2006 8:53 am    Post subject: Reply with quote
I've seen a couple v8 924s on ebay and the hood wasn't cut.
78 924 sold.
85.5 944
chris24
PostPosted: Sat Mar 18, 2006 9:12 am    Post subject: Reply with quote
...about that flat6 though Tim...?
PostPosted: Sat Mar 18, 2006 9:44 am    Post subject: Reply with quote
If you pull out your measuring stick you`ll see why all transplants so far need to cut the hood. When I measured it was 52cm from the top of the crossmember to the top of the strut towers.
When I was checking to see what commonly available 4-cylinders would fit they all failed the height test. One engine that would be nice is the SR20DET from the Nissan Silvia/200sx but that is 62cm from sump to top of rocker cover so you`d end up with at least a 5cm (2in) lump in the hood.
I`ll move this to the right forum.
