X-Kart Racer
Posted: Sat Nov 05, 2005 8:23 am Post subject: Engine Missing on #3 and #4 cylinder |
I have a 1980 NA 924 with dual Dell Orta carbs. I've had the car for about a year now and I'm finally starting to sort the engine out. The car sat for 5 yrs in a barn. When I first got it I cleaned the fuel tank and replaced the fuel lines and fired it up, but it ran really rough. Recently I have replaced the plugs, plug wires, disb cap and rotor. Today I fired it up again and I have found that cylinders 3 and 4 are not firing. My engine experience has mostly been with small engines due to my past hobby of kart racing.
So where do I start to sort out the issue with cylinders 3 and 4? (New disb?)
Thanks in advance for any help. |
jpab924
Joined: 03 Nov 2002 Posts: 1538 Location: Crown pt. IN. 50 miles southeast of Chicago Ill.
Posted: Sat Nov 05, 2005 1:05 pm Post subject: |
Spark, compression, and fuel.
If you have spark and compression, more than likely the jets in the aft carb are plugged. |
X-Kart Racer
Posted: Sun Nov 06, 2005 2:53 am Post subject: |
| Forgot to mention that I also have pulled the carbs and cleaned them. I'm going to check for spark on cylinders 3 and 4. Again, the engine cranks and runs, but when plug 3 and 4 are pulled there is no difference in the way the engine runs. So I guess you could say that I'm running a 2 cylinder engine (sounds like a John Deere 430). |
My924gtc
Posted: Sun Nov 06, 2005 3:05 am Post subject: |
Is there unburnt fuel in the cylinders? If so, ignition problem.
If not, since you are running carbs, I would say that because you are experiencing problems with these two cylinders, and they operate off the one carb, I would suspect that carb is causing a problem with fuel delivery. Keep in mind that cleaning is not quite the same as rebuilding.  _________________ MJ
'81 924 2.0L T
'82 924 2.3L SC/EFI <---online fall '06
Sponsor of the 944 Cup and Super Cup
Sponsor of the "2006 Battle in the Badlands" |
