macBdog
Joined: 16 Aug 2004 Posts: 1111 Location: Brisbane, Australia
Posted: Tue Nov 01, 2005 12:06 am Post subject: The "How to Make GT Headlights" Guide part 2 |
Part 2 of the guide is finally here. This part is alot more open ended, there are probably heaps of ways to do this part, this is how I did it rather than a definitive guide. Definite room for improvement. On with the show.
Materials requied.
1 pair GT Lenses made from part 1 of the guide
1 pair headlights (Narva 165x100mm H4 Halogen)
800mmx900mx1mm Aluminium sheet
20x Small stainless self tapping metal screws
16x Larger nuts and bolts with rounded heads
2m 2mm black vacuum hose
1 can matt black spray paint
Rubber glue
Tools required.
Good tin snips or a dremel if you are patient
Pliers
Heat Gun
Vice or clamps
Screwdrivers etc
A couple of good lengths of wood for the jaws of the vice
A few pieces of natural felt again for the vice
Marking pen and cardboard
Sharp scissors or a razorblade
Here are the headlights I used, im sure there are plenty of other suitable brands and types. I probably wouldnt go much higher than 100mm though because you would start getting clearance issues.
1) Using a piece of cardboard and the cavity for the normal popup headlights, draw out a mask for a U shaped light bucket. Each car is different (even each side of mine was different) so you will have to spend a few minutes getting this part right. My shape and resulting bucket template was roughly as follows (diagram and real):
2) Once the shape is correct and snug to the metal all around, trace the template onto the aluminum sheet and cut out using tinsnips or dremel. Then bend into shape and check your fit to the car by drilling holes for the self tapping screws and screwing down. I had to have a few cracks at this part to get it right (final version last picture):
3) Make some ear brackets for the lights so they sit securely in the bucket piece. Again this will depend on the headlight you have chosen and your own car. You can't go wrong with a carboard mockup and then transfer to the metal to cut and bend - just make sure you are mocking the brackets up with the bucket piece attached to the car. Make the higher pair of bolt holes elipses so you can adjust the lights up and down after they are in the car. Use the smooth headed bolts facing out of the bucket so they are easier to squeeze into the cavity when installing.
4) Attach the ears to the bucket and test fit once again. The reason for using 1mm aluminium is because it is flexible enough to take the shape of the curvy headlight cavities and also because it so easy to work with. You can see my completed bucket here looks all wonky but when its screwed down to the car its fine.
5) Sit the lense in place and sand down or dremel off any areas that need it so the lense fits in. Close the bonnet and mark the line of the bonnet on the lense. Take the two lengths of wood and wrap them in felt, and clamp the lense along the line that was just marked. Use the heat gun to heat up the acrylic just along the fold line. Hold the gun about 10cm above the acrylic and move back and forth across the line quickly while applying gentle pressure with the top of the lense with your other hand. In about one minute you will feel it soften and you will be able to make then bend. I couldnt get any good pics of this because the camera does not capture the acrylic. In the end results you can just see the bend of the lense over the end.
6) A quick coat of black paint smartens the whole lot up nicely. I like the black on red for my car, I know Crunchie left his silver which works well with a white car. Attach the lights to the brackets.
7) Take the vacuum tubing and run a sharp blade down one side to split the tubing. This will for the seal of the bucket to the car and the lense. Dab on some rubber glue round the outside of the bucket and push the tubing on around so the split goes either side of the metal.
Now to make the lense mountings. Cut some thin strips of aluminium and drill holes to take the self tapping screws. Bend the strips in the middle to form a right angle. Refit the buckets to the car with these little mounts in between the screwhead and the bucket.
9) Put the lense in position and mark and drill the holes for the mounts. When drilling the holes for the self tapping screws, go up one size in drillbit because it is easy to crack the acrylic when putting in the screws. Underneath where the holes are drilled, stick some self adhesive foam ti stop the lenses rattling and cracking.
10) Screw the lense down, insert the bulb into the light, attach the standard headlight connector plug and you are done!
 _________________ 1979 931 with a 350 chev
1973 911E with EFI
| p-talk wrote: | I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways  |
Stu2j
Joined: 03 Nov 2002 Posts: 1285 Location: Virginia Beach, VA
Posted: Tue Nov 01, 2005 12:15 am Post subject: |
How did you correctly aim and adjust the lens? _________________ -Stu
924 owner since 1988
924S owner since 2002
Click here to view them: |
81turbo
Posted: Tue Nov 01, 2005 3:35 am Post subject: |
Great Work!
Can we get a front shot of the finished product on the car. An entire front would help as well to see how it looks with the narrow body. |
teo
Joined: 07 Sep 2001 Posts: 637 Location: Hungary, Europe
Posted: Tue Nov 01, 2005 4:40 am Post subject: |
| Quote: | | Can we get a front shot of the finished product on the car. An entire front would help as well to see how it looks with the narrow body. |
see Part 1. |
81turbo
Posted: Tue Nov 01, 2005 4:42 am Post subject: |
| I saw that, I just want to see it on a car w/o the funky front bumper. |
Posted: Tue Nov 01, 2005 12:31 pm Post subject: |
So the ear brackets fit up snug to the side of the headlight
and hold it securely. Looks good. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Wed Nov 02, 2005 2:21 pm Post subject: |
Kudos to macBdog. Excellent writeup. Will definitely be referring to this when I re-do the buckets in my wide-body! I plan to create a few modifications to accomodate dual 3" PIAA style HIDs...but the bucket concept should work just the same. Thanks for taking time to document the process! _________________ erstwhile owner of just about every 924 variant ever made |
macBdog
Posted: Wed Nov 02, 2005 5:25 pm Post subject: |
Thanks heaps guys. I will get a front on shot of the car when I finish the second headlight. One last tip is to make the bottom of the bucket paralell with the bumper. Because mine slope inwards and it makes the car look a bit weird, maybe a little bit angry. _________________ 1979 931 with a 350 chev
1973 911E with EFI
Posted: Wed Nov 02, 2005 6:49 pm Post subject: |
| ideola wrote: | | Kudos to macBdog. Excellent writeup. Will definitely be referring to this when I re-do the buckets in my wide-body! I plan to create a few modifications to accomodate dual 3" PIAA style HIDs...but the bucket concept should work just the same. Thanks for taking time to document the process! |
ideola, if you're going to do a variation why not pull out the camera and do an extension to macBdog's superb work? _________________ 1979 924 (Gone to a better place)
Learn to love your multimeter and may the search be with you |
jamez
Joined: 03 Nov 2002 Posts: 401 Location: Chehalis, Wa
xpernet
Joined: 07 Apr 2004 Posts: 414 Location: Kitchener, Ontario Canada
Posted: Fri Nov 04, 2005 1:54 pm Post subject: |
Wow, looks great. Good work on the guide!!!
There is one thing that i would like to know: How do the headlights perform during night? Do they give the same illumination as the Pop-up setup?
If they give enough light or not, I would wish that i could do the conversion right now! It would look great on my 924 since it has a widebody. I miss my 924
xpernet _________________ 1977 Porsche 924
Sunroof Delete
Megasquirt II EFI & EDIS
Carrera GTS / 944 Body
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
macBdog
Posted: Wed Nov 09, 2005 10:18 am Post subject: |
A few more pictures
1973 911E with EFI
timstar92404
Joined: 22 Sep 2004 Posts: 2075 Location: richmond BC
Posted: Fri Nov 25, 2005 3:53 am Post subject: |
how do you bend the metal sheet correctly?
also how do bend the little metal strips into right angles?
looks like alot of trial and error.
the hardest part looks like melting the lenses.
would a high heat heat gun work? I'm guessing won't because the heat won't be equal in all spots and will melt one spot at a time and wreck it but I have no other way of trying.
I wouldn't use my house oven because of risk of fire or explosion. _________________ 78 924 sold.
85.5 944 |
timstar92404
Posted: Fri Nov 25, 2005 3:56 am Post subject: |
I remember taking metal design in highschool and you need a device to bend the metal in angles.....
so else can you bend the alluminum ? _________________ 78 924 sold.
85.5 944 |
Posted: Fri Nov 25, 2005 4:23 am Post subject: |
It's called a sheet metal brake, but I have a piece of angle iron on one edge of my bench that I use most of the time. You just place the metal fold line in line with the edge of the angle iron and tap away with a body hammer. _________________ White 87 924S "Ghost"
