Cbass Guest
Posted: Wed Mar 27, 2002 12:53 pm Post subject: |
I haven't heard much about 1.8 turbo swaps here. It seems like a logical swap to do, same basic size, slant, all the modern goodies.
I have been told all the bellhousings are the same for Audis and VWs since the 70s, so wouldn't it be possible to mate the 1.8T and it's clutch to the torque tube?
The two difficulties would be mounting it, which I'm fairly confident I could do, relying on my past experience, and the wiring, which my brother could do relying on his past experiences.
It might just be crazy enough to work. |
Richard Guest
Posted: Tue Apr 02, 2002 2:12 pm Post subject: |
| What's the torque and HP look like. Do you gain more by losing displacement with this motor as compared to a 924 turbo? |
ricomartinez Guest
Posted: Tue Apr 02, 2002 4:40 pm Post subject: |
Are you kidding me? That thing is awesome! 150hp @ 5700, 155ft-lbs @ 1750-4600. TWENTY-EIGHT hundred and plus rpm's at 155 ft-lbs of torque!
The new ones are 180hp and 174ft-lbs! Don't know rpm's, but it's probably as broad as the earlier one. Some of the VW/Audi tuners on the web say that 200hp is but a chip away. This thing in stock form would probably get better mileage than the N/A's in stock form too. |
Cbass Guest
Posted: Wed Apr 03, 2002 9:07 am Post subject: |
I can guarantee it would get better mileage, the 20V 1.8T is a very efficient motor.
It also makes 225hp in the Audi TT. The TT has some different intake parts, and a bigger exhaust turbine on the turbo.
I have also seen these motors reliably tuned to as much as 500hp. They are beautiful motors. |
Benski Guest
Posted: Wed Apr 03, 2002 9:15 am Post subject: |
Anyone know how much one of these motors would cost used? Or know of a good place to get them?
The best thing to do would be to get an empty engine block from one. That way you could try to figure out if it mounts and if not how to fabricate it - and without the annoyance of a large heavy engine.
I've got some spares 924's and have been dying to use one as a guinea pig. I just need a cheap 1.8t engine core to mess with to see if it works!
Cbass Guest
Posted: Thu Apr 04, 2002 10:13 am Post subject: |
The downside is that they are very new motors. The upside is that VW puts them in almost everything they make, and the aftermarket community for them is HUGE.
I'm sure it wouldn't be to hard to find a wrecker who doesn't think a 4 cyl from a VW is worth a lot. You can get one new for about $6000. I figure a cost of about $2000-$4000, depending on who you get it from, and what you get it with. Find a good wrecker, and get the radiator and all the accessories.
I am opening up my shop in about 2 months, and this will be my first project. |
Benski Guest
Cbass Guest
Posted: Fri Apr 05, 2002 3:17 pm Post subject: |
Well, we can't hope for everything. The 1.8T won't mount in a 924.
However, with a little bit of cutting and welding, it will. Further more, once I've done this, I think I'll offer a kit, so anyone who wants one can do it.
God I love the prospect of running my own shop. |
81turbo Guest
Posted: Fri Jun 21, 2002 9:37 am Post subject: |
| Just get a 931 and do a front mount intercooler and a boost controler. if you do a good job you will maintain your Porsche power plant and make 200+ Hp with not all that much work. |
Cbass Guest
Posted: Fri Jun 21, 2002 5:30 pm Post subject: |
Yeah, but 931s can be hard to find, especially ones that aren't horrible money pits.
There are lots of NA's out there, and a cheap parts car to play around with can be had for less than $1000
Posted: Sat Jan 01, 2005 1:45 am Post subject: Cbass did you ever try this? |
Just wondering if you ever determined if the Audi TT motor would fit. My wife has the 225 hp version of this motor in her TT.
Wonder if she would notice if I borrowed it for awhile?  _________________ White 87 924S "Ghost"
CBass
Joined: 03 Nov 2002 Posts: 2807 Location: Vancouver, Canada
Posted: Tue Jan 18, 2005 7:10 am Post subject: |
While I haven't confirmed this with my own eyes, everybody seems to agree that the Audi and VW bellhousing patterns are common. I have no idea if a 924 driveshaft will fit into the pilot bearing of the 1.8t, but it stands to reason that it could be machined into working. Even if the VW input shaft tip is significantly smaller than the vw's, a machinist could make a spacer to fit a 924 bearing.
I have found out that the Audi 1.8t and the Passat 1.8t are longitudinally mounted, but I don't think the block is different at all. I'll have to find some pics of the mounting.
It may be possible to modify a 924 mount or fabricate new mounts to fit them to the side of the 1.8t block, and use the original 924 mounting locations. Another option would be to cut out VW body mounts from a donor car and weld them to the 924 body. _________________ '81 931 in various states of assembly |
moone924
Joined: 05 Feb 2003 Posts: 868 Location: Douglas Wyoming
Posted: Sat Mar 05, 2005 7:04 am Post subject: |
Audi is replacing the 1.8T with a new 2.0T.... I looking forward to seeing the specs _________________ Ryan Moone
Always shopping for a nice s2 931 to baby.
New philosophy : one car project at a time. |
