16 valve
cgoldhill
PostPosted: Tue Oct 19, 2004 9:43 am    Post subject: 16 valve Reply with quote
Can the 16 valve heads from the 944s just be swapped over to the 924s? If so, what parts are needed to do the swap over? The head and ecu or the intake and exhaust manifold and alot more complicated things?
The Fife
PostPosted: Tue Oct 19, 2004 11:43 am    Post subject: Reply with quote
My guess is that you'll need a different intake, intake manifold, and exhaust, and computer.
PostPosted: Tue Oct 19, 2004 12:16 pm    Post subject: Reply with quote
Here's an opinion:
http://clarks-garage.com/phpBB2/viewtopic.php?t=838&highlight=16+valve
cgoldhill
PostPosted: Tue Oct 19, 2004 11:25 pm    Post subject: Reply with quote
So if the 16 valve head conversion isn't cost effective then how much power would expect from a 924s with a mildly port and polished head (no valve job), new DME chip, k&n air filter and a nice free flow exhaust (low restriction cat, 2.5 inch exhaust, high flow muffler)?
gohim
PostPosted: Wed Oct 20, 2004 5:04 am    Post subject: Reply with quote
People have been screwing with the 944 engine for over 20 years, and there isn't much power to be had cheaply.
You might get a few hp from a reputable company's DME chip (somewhere between 5-10hp with a change in the power curve if you believe the advertising), but the fallout would be the requirement of premium grade fuel. You get nothing from the K&N air filter, and maybe 5hp from a well designed free flow exhaust system.
cgoldhill
PostPosted: Wed Oct 20, 2004 5:43 am    Post subject: Reply with quote
What about the mildly port and polished head?
gohim
PostPosted: Wed Oct 20, 2004 7:03 am    Post subject: Reply with quote
I would not waste the money on a port and polish, unless the head was already off for another reason (blown head gasket or bent valves), and the work was going to be done a a professional service (ie: extrudehone).
Allowing an idiot unexperienced in working on 944 heads with a grinding tool to simply grind on the head will not yield any improvement and could actually lower performance (lowering the flow rate will lower performance). You need more flow with the same or improved flow rate. and you need an experienced 944 technician to get this.
