mustangporsche
Joined: 08 Oct 2003 Posts: 283 Location: California Lodi
Posted: Thu Nov 13, 2003 8:20 am Post subject: turbo question |
| Will a 1980 931 turbo work in my 1981 931? Are they the same??? |
Posted: Thu Nov 13, 2003 8:50 am Post subject: |
a 1980 931 turbo will swap in the spot of a 1981 931 turbo, however the 1980 unit has a larger compressor and in turn spools up slower but has the ability to create more boost but you would never hit the boost levels at which would make a difference at or could obtain _________________ 3 928s, |
numbbers
Posted: Thu Nov 13, 2003 11:10 am Post subject: |
physically the same. But '80 will flow more air at high end. The trade off is that boost comes in about 500 RPM later on the '80. _________________ 1980 924 Turbo |
SprintStar
Posted: Fri Nov 21, 2003 12:20 pm Post subject: |
| Lizard wrote: | | a 1980 931 turbo will swap in the spot of a 1981 931 turbo, however the 1980 unit has a larger compressor and in turn spools up slower but has the ability to create more boost but you would never hit the boost levels at which would make a difference at or could obtain |
Will never hit the boost levels due to the wastegate or boost pressure switch for the fuel cut? Anyone has flow charts for the various turbos? How much max boost can each run?
Sprint. |
Kenodog
Posted: Fri Nov 21, 2003 4:11 pm Post subject: |
doesn't matter,you'll hear a nasty great bang before you get there.  _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
