Wiz-PORSCHE-924
Joined: 06 Nov 2002 Posts: 214 Location: Douglassville PA
Posted: Mon Oct 13, 2003 10:58 am Post subject: HELP !! It still wont start. |
| This thing is starting to really get me angry. Ive tried EVERYTHING !!!!! I changed the plugs, wires ,cap, rotor, the fuel pump, the fuel filter. WHAT GOES ! Any suggestions ??? |
augidog
Posted: Mon Oct 13, 2003 11:09 am Post subject: |
are you getting spark? (spark test against body or distributor cap.)(hold with insulated tool please)
are you getting fuel? Is the Fuel relay good or the fuse on it good? Is their a gas smell on the plug? _________________ 1978 924 95 mile daily driver.
Audi TB/POR174M/High Flow Cat/2.25" exhaust
I knew that positive thinking thing wouldn't work. |
Posted: Mon Oct 13, 2003 11:27 am Post subject: |
Was it ever running for you? - Then did something and it stopped working? (removed-replaced timing belt, distributor, anything else?) Got past that no fuel at the engine problem? _________________ "..it's made in Germany. You know the Germans always make good stuff."
