w.a.
Joined: 27 May 2003 Posts: 19 Location: Danville, Virginia
Posted: Tue Aug 26, 2003 12:12 pm Post subject: Clutch/Brake Pedal - distance from throttle |
What, if anything, have some of you done to get the right distance between the brake and throttle to maximize your heel-and-toe?
The brake pedal on my '76 is so close to the throttle that I blasted through the cones at the entrance to the infield section at Charlotte Motor Speedway last week because I had my foot on the brake and throttle at the same time during my downshift
Best,
w.a. _________________ '92 968 Coupe, Black/Tan
'76 924 J Stock Racer
"If you are not living life on the edge, you are taking up too much space." |
Lizard
Posted: Tue Aug 26, 2003 3:01 pm Post subject: |
amputation at the neck  _________________ 3 928s, |
Neil924
Posted: Wed Aug 27, 2003 7:39 am Post subject: |
I have fairly large feet {large body too I guess} I own only one set of footware that I can use to drive my car. They are a pair of sneakers I used for mowing the lawn. They are 5 years old and look like hell and are as tight as hell in a dress. I am going to buy a pair of racing shoes when I get the car back on the road. I am out of options.  |
Joined: 29 Jul 2001 Posts: 9080 Location: Royal Oak, MI, USA
Posted: Thu Aug 28, 2003 10:50 pm Post subject: |
I run an extra-wide accel pedal, but have racing shoes of course. Have no issues heel-n-toeing... _________________ Vaughan Scott
Neil924
Posted: Fri Aug 29, 2003 7:00 am Post subject: |
I guess in emergencies it's better to get on the throttle instead of the brakes, eh racerboy? You may wreck your car and injure hundreds of people possibly killing dozens of them and probably yourself too. But you know what you just may gain a few tenths on the leaders or even gain a position. And that's what it's all about. Or at least that's the way I see it on my way to and from work everyday!  |
jjadczak
Joined: 03 Jan 2003 Posts: 346 Location: Accokeek, MD
Posted: Wed Sep 03, 2003 11:16 pm Post subject: |
Get a pair of racing shoes. Their the best. Racer wholesaler sells them for about $60.
Jeremy |
w.a.
Posted: Thu Sep 04, 2003 12:24 pm Post subject: |
| Quote: | | Get a pair of racing shoes. Their the best. Racer wholesaler sells them for about $60. |
Jeremy, thanks for the suggestion, however, I have racing shoes. The problem is that (at least in the '76 version) the pedals are extremely close together. In my 968, I'm used to catching the brake with my big toe and the upper right portion of the ball of my foot. This gives me ample extension to blip the throtte with the right side of my right foot. Unfortunately with the 924, if I have any portion of my foot to the right of the brake, I engage the throttle at the same time. There is no need to roll my foot to the right I'm taking her in to the welding shop in a few days to try and sort this out. Maybe we can heat the metal and bend it, maybe the best solution is going to be exactly what Lizard suggested, cut off their heads and weld them back
BTW, while we are at this, (and I have checked the Haynes) can the brake pedal be manually adjusted outward ( toward the driver)? That could give me a little extra room too. If not, we can always weld an extension on the pedal when we move it to the left.
Thanks guys for your help. I, along with my friends Jesse and Lawrence are headed off to NASA comp school later this month at CMP in Kershaw, SC. Hope to catch up with many of you in the 944 Cup next year (literally and figuratively ).
Best,
Posted: Thu Sep 04, 2003 10:09 pm Post subject: |
Yes, the brake pedal can be adjusted, on the rod that goes into the booster. Loosen locknut and rotate rod.
Are you using the stock gas pedal? Skinny plastic pedal? Doesn't sound like it... _________________ Vaughan Scott
w.a.
Posted: Fri Sep 05, 2003 3:07 am Post subject: |
Yes, the gas pedal is stock.
Best,
Posted: Fri Sep 05, 2003 10:56 pm Post subject: |
Man, you got big feets! j/k
I am kinda wondering now if perhaps your brake pedal is already bent? I ought to take some measurements to compare across my fleet. I have a wider aftermarket (actually, homemade) gas pedal to assist me for heel-n-toe. I would (on casual thought) expect the pedals to be similar to your 968. I take it they are not?
I could also compare with my neighbor's 951, which should be very similar to your 968... _________________ Vaughan Scott
w.a.
Posted: Sat Sep 06, 2003 8:23 am Post subject: |
Yeah!!! Size 13! But my feet >are< narrow. Every other 924 I've been in is set up more like my 968. [/u] _________________ '92 968 Coupe, Black/Tan
Minus000
Joined: 29 May 2003 Posts: 363 Location: Sidney, B.C.
Posted: Sat Sep 06, 2003 10:54 am Post subject: |
| 13 is nothing, try 16. only some shoes will FIT between the gas and brake. I am thinking about trimming and relocating the brake clutch pedal over to the left more. |
