Right Headlight
DanB
PostPosted: Tue Jul 29, 2003 7:40 am    Post subject: Right Headlight Reply with quote
The right headlight on my 88 924S doesn't have any juice. Left side voltage tested fine, but the right didn't budge the needle. Checked the fuses under the dash (above driver's left knee) and all appear fine. Is there another fuse block that I don't know about? The Haynes 944 manual says there's one in the engine compartment on the firewall, must not apply to the 924S, 'cuz I didn't see one...
Any suggestions???
Thanks for any help,
Dan
PostPosted: Tue Jul 29, 2003 9:07 am    Post subject: Reply with quote
what are you grounding it too cause the headlight ground could be hooped, also it could be the pins on the fuse box that have burned up not letting any juice through
3 928s,
Jesus
PostPosted: Tue Jul 29, 2003 9:54 am    Post subject: Reply with quote
Does it have anything you dont know about these cars?!
For how long do you own a porsche?
Et la lumière fut...
PostPosted: Tue Jul 29, 2003 10:30 am    Post subject: Reply with quote
I have owned a porsche since feb 16th 2002, and I have a photographic memory and absorb info like a spong absorbs water, plus I am very mechanically inclined
3 928s,
Neil924
PostPosted: Tue Jul 29, 2003 10:51 am    Post subject: Reply with quote
What is the meaning of: "Et la lumière fut"
PostPosted: Tue Jul 29, 2003 10:58 am    Post subject: Reply with quote
accordingto a online translator it means "And the light was", but more probably it mean and there was light
3 928s,
Sleykin
PostPosted: Tue Jul 29, 2003 11:25 am    Post subject: Reply with quote
Mine did the same thing only with the left headlight. Turned out to be the wires where they make the turns to go with the light when it opens and closes. Two wires were broken. Back up the harness a bit past the part that flexes a lot and put a pin through the wire to see if it is hot there.
Glenn
Glenn Neff
Medford, OR
87' 924S
78porsche924
PostPosted: Tue Jul 29, 2003 2:25 pm    Post subject: Reply with quote
You see when u become completely anal about your car, you will go and fix everything. Sounds like lizard is one of those seriously anal guys
90 944 S2
78 924 NA <---now sold and killed by new owner
snailshell trans
Bae turbo kit
to check out my 944 S2 http://www.cardomain.com/member_pages/view_page.pl?page_id=388139
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger
PostPosted: Tue Jul 29, 2003 3:24 pm    Post subject: Reply with quote
hahahahahahahaha yah right I know how to fix it but alot of the time am too lazy to go and do it, then I will all of a sudden get modivated and go and do a ton of them at once
3 928s,
78porsche924
PostPosted: Tue Jul 29, 2003 4:09 pm    Post subject: Reply with quote
I am too, except i don't know how to fix it, i just rip it apart and pray i remember how to put it back together. For example, i ripped the top off the 944 to replace it, that was a couple days ago. Still trying to figure out how to reinstall it correctly
90 944 S2
snailshell trans
Bae turbo kit
PostPosted: Wed Jul 30, 2003 2:09 am    Post subject: Reply with quote
see I have a photographic memory so I wouldn't have a trouble putting it back on, but wtf was the reason for removing it
3 928s,
78porsche924
PostPosted: Wed Jul 30, 2003 4:29 am    Post subject: Reply with quote
Back window has a small tear in it same with the top piece so i am replacing it. I know how it goes on, i just gotta get it on without big pockets and wrinkles. Its a lot harder then i thought.
90 944 S2
snailshell trans
Bae turbo kit
