Please help... Euro 931 bogging after launch/ rough idle
mrgtturbo
PostPosted: Fri Apr 04, 2003 6:21 pm    Post subject: Please help... Euro 931 bogging after launch/ rough idle Reply with quote
Last fall I bought my Euro 931, it had a slightly dry-rotted intake boot, (the boot below the sensor plate/ above the turbo). Well, my turbo started leaking alittle, (come to find out it was an O-ring at the oil intake). I put it up in storage till this spring. I replaced the boot and rebuilt the turbo just the same, (already bought the kit)... the car ran great. Soon after I noticed a missfire was coming to be. It wasn't idleing that great, and occationaly backfired under heavy boost. I checked the plugs, they were a little toasty from age, but I also found that my coil wire had a pin hole in the top of it. The connector at the distributor end was corroded as well as that one connector in the cap. I ordered and replaced the old AC plugs with the proper Boshe. I also ordered and replaced the wires, the cap, and the rotor button. The backfire problem was solved, the idle problem was not.
Now all the sudden it takes off crappy then you feel some of the torque kick in at about 2k RPM, but it's short lived. By 2200 RPM your torque feels to be gone, but it's beginning to boost. At this point there is so little power that it feels like it wont make it too 3k RPM, but when it finaly does it sets you back and just burns the tires.
I know these cars are a little sluggish before the boost comes in, (compaired to some cars), and when they boost they boost strong. But this is a very noticable differance from before this problem. It's also seeming to have alot harder time starting now. When I first start it in the morning it stalls, and I have to start it 2 more times, on the 3rd start it stays running like it never had a problem in the first place. I can go out driving, come home, shut it down, and while it's still warm go to start it back up and it takes about 10 seconds of turning over to start.
Maybe these things are not related, but I can't help but think they must be. The car still runs very strong over 3k RPM.
Please if anyone can help me figure this out I'd greatly appreciate it.
Oh... one more thing. When this bogging first started, it wasn't all the time. A couple times it was bogging, so I planned it to at the next light aswell. I gave it a little more gas then at the light before and it decided not to bog but instead just go... ass end slipping sideways. This is way it's so mind boggling to me, I'm sure it's nothing too serious, but I'm a little afraid it's gonna be expensive. I'd be so happy to figure this out the first time, I can't really afford not to.
Please help, and a big thanks for your taking the time to read this.
Aaron
81' 931
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
PostPosted: Fri Apr 04, 2003 9:58 pm    Post subject: Reply with quote
Have you adjusted the mixture and idle? Might be very off, if it was adjusted to compensate for a leaky boot.
PostPosted: Sat Apr 05, 2003 7:30 am    Post subject: Reply with quote
Also double check the plumbing between the turbo and throttle - check those orange o-rings. Especially the lower one between the turbo compressor outlet and lower pressure pipe. Make sure the bracket that holds the lower pressure pipe to the block is attached - this holds the pipe in place to the turbo.
Alex Roy
PostPosted: Sat Apr 05, 2003 7:46 am    Post subject: Reply with quote
I had the same symptoms as you...and it turned out to be that the frequency valve had the ground wire disconnected so it wasn't regulating the fuel pressure properly.
mrgtturbo
PostPosted: Sat Apr 05, 2003 9:19 am    Post subject: Reply with quote
I have to admit, what your saying makes a little since to me... but not alot at this time.
The mixture part does make me think. When I bought the car the previous owner did tell me that the mixture had been enriched to handle the higher boost. I'm not sure what exactly he did to do this, but I know whatever he said to me was honest. It's the only time I ever bought a car that the owner held it for me, giving me time to come up witht the cash when others were interested and could pay that day, just because of my love for the car. He never tried to brag it up, the slightest problem was alot bigger in his eyes then my own, (right down to a little tiny dent in the bottom of the muffler). The guy was crying when he sold it to me. the only thing that seemed to ease his pain was the fact I rented a storage shed so it wouldn't have to see the salt and snow he protected it from for many years. The car was like a part of his family, and you could tell whatever was done was done right. I guess all this really did not need be said, but... it has been a very well mantained car, and it came with plenty of paperwork to prove it. I just want to set the picture here because I'm sure whatever is wrong with it is my fault, and I've done little to it.
Back to you suggestions;
The Idle part doesn't make since to me. However that may be due to my lack of knowledge. As far as I knew the idle could only be altered, (as in speed), through thottle cable adjustment, but this wouldn't change the mixture. If this is wrong, please clarify. I'm pretty sure a screwed up idle causing change in mixture can only be caused from plugs, wires, distrib, rotor butt, timing belt, and coil? Anything else would be a fuel or air issue that would result in a chang in the idle. Again I could be wrong, and if so please explain. Knowledge is power, and Porsches make me weak at the knees. lol
I do truly appreciate your input, as I do everyone who wrote in so far. Thank you.
81' 931
PostPosted: Sat Apr 05, 2003 9:26 am    Post subject: Reply with quote
check this post http://www.924board.org/viewtopic.php?t=6654 it has a pic of how the fuel system works, and do a search on the board be aware though when searching for say fuel mixture it HAS to be typed like this "fuel AND mixture"
3 928s,
mrgtturbo
PostPosted: Sat Apr 05, 2003 9:39 am    Post subject: Reply with quote
Smoothie wrote:
Also double check the plumbing between the turbo and throttle.
If you're talking about the aluminum tube to the plenum, how do you check that exactly. If they "can" crack could it accualy be seen?
[quote=]check those orange o-rings. Especially the lower one between the turbo compressor outlet and lower pressure pipe. [/quote]
I didn't replace the orange O-ring on the top of the turbo, (connecting to the above mentioned intake tube), when doing the turbo rebuild/ replace. It looked good, and the replacement didn't come in till a week or so after the reinstallation was done. But as I said it looked good so I wasn't worried about it. It is on the agenda to be replaced some time soon, (just because I have it), but could this really cause the power loss at low end, wouldn't it mostly effect my boost?
[quote=]Make sure the bracket that holds the lower pressure pipe to the block is attached - this holds the pipe in place to the turbo. [/quote]
This wasn't connected when I started the removal, so I didn't worry about it. It does however appear to me that the turbo isn't exactly allighned straight with the intake tube. The only correction I can see to this would be lossening up half of the turbo and spinning it a hair. I don't know if this would upset the seals or not... that's why I've been in no hurry to do this. The seals were coated in vassiline when put together, so I would assume they'd be ok... but haven't been brave enough to gamble it. I have heard a slight vaccume leak under boost. The boost seemed uneffected, and I can't even feel the seal with my fingers so I figured it to be ok, and the sound of a vaccume leak to be caused by my bloost control, (which ofcourse isn't really a leak).
Whatever ferther input on this you could give me would be great.
Thanks.
81' 931
mrgtturbo
PostPosted: Sat Apr 05, 2003 9:45 am    Post subject: Reply with quote
Frequency valve? What the hell is this and where do I find it?
Hope the Haynes Manual lists it. I must say Haynes may be handy, but it definatly leaves something to be desired.
Thanks
81' 931
mrgtturbo
PostPosted: Sat Apr 05, 2003 9:48 am    Post subject: Reply with quote
Exact phrase... never gave that any thought. Thanks for the tip.
and away I go to check out your link. :thumbup:
81' 931
PostPosted: Sat Apr 05, 2003 10:55 am    Post subject: Reply with quote
That bracket is important because even if the seal (orange o-ring) is good, the pipe still needs to be held down to the turbo. I had this problem a couple months ago and didn't realize what it was 'til I looked up at the joint from below and could see a bit of the o-ring showing. While driving, the joint can be pulled further apart by engine torque and the boost itself. As a quick fix, I wrapped wire around the whole assembly from upper pipe to down around the turbo to pull everything together. Click on "Photos <click>" below. In my case the compressor side of the turbo rotates without having to loosen the bolts on it, so when I'd push down on the pipe from above it rotated together for a tighter fit. If you have a problem with it at idle, just push down on that pipe and see if it clears up.
- I don't think cracking is a common problem with those pipes.
You should find the frequency valve just in front of the throttle. See pics linked to from my post here: http://www.924board.org/viewtopic.php?t=6605
mrgtturbo
PostPosted: Sat Apr 05, 2003 11:18 am    Post subject: Reply with quote
Could this really cause the problems I'm having at low RPM's vs high RPM's?
I would think this would cause more of a problem at the higher RPM's when the intake tube is pressurized. I'm sure you know more about this issue then I do, maybe I'm just not noticing it at higher RPM's because of the kick of the turbo. Don't know.
I will give this a shot ASAP, and you may be right on the money. I've given this some thought before, (as in the orange O-ring and allighnment of the turbo vs the tube), but like I said, I just can't see this being a low RPM issue.
Since this apparently could be, would you mind explaining to me why? Just so I may further understand my car. I'm not a mechanic by no means, but I do try to do my own work. I have a healthy knowledge of cars due to asking questions like this. So please don't feel that I'm trying to put you on the spot or trying to tell you your wrong... because I'm not, not at all !!! Just want to understand more.
Thanks. Hopefully this turns out to be the whole problem.
81' 931
PostPosted: Sat Apr 05, 2003 11:34 am    Post subject: Reply with quote
I had the problem with it only at higher rpms because the joint would pull apart further with boost, but if a gap exists even before the boost comes on, then this could be your problem. It's too easy not to check - just push down on the pipe.
Also have a look at this topic: http://www.924board.org/viewtopic.php?t=5294
If the ring is bad, you'll have a huge vacuum leak until the turbo spools up, then you'll have a huge boost leak.
Alex Roy
PostPosted: Sat Apr 05, 2003 12:04 pm    Post subject: Reply with quote
The frequency valve looks like an EFI injector, except that it has hoses connected to both ends. It is loose, cradled in the inside of the curving intake runners right at the front. When the car is running, it should be buzzing. The frequency valve is what the O2 sensor (lambda) system uses to modify the fuel pressure in the system.
The easiest way to test it that I found, is to unbolt the lambda box from under the steering wheel and unplug the long wire harness so it disables the lambda system and makes the car run like a normal CIS system. You'll have to turn your idle adjustment screw down when you unplug this because your idle should jump up to about 2000 RPM. Then take your car for a short drive and see if the car runs better, if it does, something in your lambda system is the problem.
CMXXXI
PostPosted: Sat Apr 05, 2003 2:13 pm    Post subject: Reply with quote
These engines are incredibly sensitive (and unforgiving) to vacuum and air leaks down-stream of the air mixture unit. Since the fuel metering is almost entirely based on the amount of air flowing past the sensor plate, any leaks affect the mixture. If you had dry-rotted rubber boots they may have been leaking air. And, if the PO enriched the mixture to compensate for the extra (un-metered) air, this could/would have substantial consequences.
If you don't have a Haynes manual yet, we all recommend you get one and become familiar with the CIS system. It'll pay for itself in no time! There is a tremendous amount of "institutional knowledge" on this site. Start with the FAQ's. (and test the site's "Search" function for us - we've had mixed results lately).
Welcome aboard,
Mark
'79 Eurospec 931
