exhaust parts
timstar92404
PostPosted: Thu Mar 02, 2006 5:46 pm    Post subject: exhaust parts Reply with quote
I'm replacing my entire exhaust system with new parts from the engine to the muffler. I want to replace the exhaust manifold aswell with an aftermarket "header" I'm wondering where is the best place to order one. Also will the header attach to the oem downpipe?
this is kind of a dumb question but how would the rest of the exhaust attach to the downpipe if it doesn't have the same type of connection made to attache the downpipe
I'm going to add a catalytic convertor aswell both for emissions and lowering noise level.
last question can the EGR sytem, I think comes from the downpipe connection be bypassed? is this easy to do and would it have a big effect on emissions?
78 924 sold.
85.5 944
5150
PostPosted: Thu Mar 02, 2006 5:55 pm    Post subject: Reply with quote
Erm, then it won't?!
You'll need a header that's specifically for the car, failing that you're going to need an exhaust fabricator to make the pipes up bespoke for you...
Mars Red '78 Euro 924 n/a
http://www.cardomain.com/id/5150_uk
Graphite? Grey Metallic '85 (late model) 944 2.5
There are two kinds of pedestrians: the quick and the dead.
Mike924
PostPosted: Thu Mar 02, 2006 6:15 pm    Post subject: Reply with quote
Tim, get it out of your head that a cat will reduce the noise level.
5150
PostPosted: Thu Mar 02, 2006 6:31 pm    Post subject: Reply with quote
What about a dog?
timstar92404
PostPosted: Thu Mar 02, 2006 6:39 pm    Post subject: Reply with quote
well its a fact that the cat will reduce some noise. but instead of getting a cat its much more effective to get a quiter muffler.... the muffler I have now is a straight through fiberglass muffler it is not designed to be quiet and my car has no cat or resonator so it is pretty loud when reving the engine in low gear but its okay when cruising.
noise is not a big deal though that's not why I'm changing my exhaust I just want to have a all new exhaust so I know for sure it doesn't have leaks or won't start leaking.
the cat can still help with emissions but I was told a proper cat will cost 400cdn, the cheaper ones don't last more than 6months to a year. I have to go through smog check in June and will most likely fail.
last time I passed because I believe the mechanic played with the timing and he took it to the test centre himself. he claimed I needed new injector seals / new intake seal which he changed.
78 924 sold.
85.5 944
timstar92404
PostPosted: Thu Mar 02, 2006 6:44 pm    Post subject: Reply with quote
I know you need a header made to fit the car that's obvious and the downpipe also has to fit. but does the stock downpipe fit to an aftermarket header?
and would you have to have special exhaust pipe connectors to attach the exhaust piping to the downpipe or would the muffler guy have the correct connectors.
I still think a cat is a good idea, it would make the exhaust much cleaner. Right now my car is probably putting out more pollution than a bus.
78 924 sold.
85.5 944
timstar92404
PostPosted: Thu Mar 02, 2006 6:49 pm    Post subject: Reply with quote
unrelated question, today after class when I got in my car the shifter would not go into first or second gear, I had the clutch fully depressed and the car was running but I couldn't get the shiter to move into first or second but it went into third and forth and then it was fine again.... the shiter is always hard to push into gear it doesn't move smoothly.
should I be worried about this?
78 924 sold.
85.5 944
Mike924
PostPosted: Thu Mar 02, 2006 7:00 pm    Post subject: Reply with quote
It depends on the make. If the manufacturers have done their research properly, it should fit the standard pipe no problem. Some cut corners in this area, charge less, but you pay later in fitting problems. Some headers are designed only to fit their own make of replacement exhaust system. You need to shop around.
If you're getting the system fitted professionally, I would expect the fitter to supply the sundry connectors and fixings, etc (and charge for them...)
I think your main problem here is that your car is simply set to run too rich. Fix that and you'll probably find that it will sail through the air test. Sure a cat will clean it up further, but if you leave your car running rich you will wreck the cat in no time!
timstar92404
PostPosted: Thu Mar 02, 2006 7:07 pm    Post subject: Reply with quote
thats what I thought, if the engine isn't running properly, mine isn't it'll just wreck the 400 dollar cat.... I thought any unburnt fuel getting on the cat will wreck it immediately.
Only header I have seen on the net is the msds I think they are 250 dollars but I'm not sure how much it would cost to ship to Canada.
my car has had the fuel mixture set twice..... once just a month ago according to the mechanic they ran the car on a gas analyser or whatever its called. Everyone still tells me the exhaust smells rich.
78 924 sold.
85.5 944
5150
PostPosted: Thu Mar 02, 2006 7:13 pm    Post subject: Reply with quote
Why not just fit all the standard parts for your model, at least then you'll know they'll all bolt in correctly with no messing around?
timstar92404
PostPosted: Thu Mar 02, 2006 7:16 pm    Post subject: Reply with quote
what do you mean by standard parts? I'm going to use the oem downpipe, I want to replace the manifold and then the rest of the exhaust to the muffler.I thought the only parts that you would need are the header/ downpipe the rest the muffler shop can build for you, am I wrong?
right now my exhaust from the cat back is new so those could be reused.
78 924 sold.
85.5 944
5150
PostPosted: Thu Mar 02, 2006 8:51 pm    Post subject: Reply with quote
Dunno how things are done over there mate, but here I can buy all the sections pre-fabricated and just fit them straight to the car.
My UK '78 only has 4 parts - Manifold, downpipe, small centre silencer and then a long rear section with a small silencer then the main back-box.
timstar92404
PostPosted: Thu Mar 02, 2006 9:11 pm    Post subject: Reply with quote
I think a "silencer" or resonator would be a good idea to keep the noise down. I read that you ahve to remove the head to install the aftermarket headers that would cost alot in labour.
another question do you guys think it would be a waste of money if I install a rebuilt head on my engine, I'm thinking of doing this in the summer. It wouldn't be a bad idea with a high milliage engine right....
I have around 3000 dollars to waste I guess.... I want to use it all to do mechanical work on the car, I'm guessing exhaust with header, resonator, pipes and labour would cost 1000 more if I get a good cat.
78 924 sold.
85.5 944
PORSCHEV
PostPosted: Thu Mar 02, 2006 10:31 pm    Post subject: Reply with quote
Wow Tim....last week the car was for sale on ebay....today your rebuilding it. Are you on drugs?? Your like a woman trying to get ready for a night on the town....you change your mind like a woman changes outfits.
Answer this question....have you ever fixed the areas where you found carbon monoxide levels to be leaking in?
Now your going to change your entire exhaust.....and put on a cat to make it quiet. But your going to install a header that will make it louder!!
I don't know why I bother!!! Not a word will even sink in...lol
1978-#53 "D" track racer.
timstar92404
PostPosted: Thu Mar 02, 2006 10:59 pm    Post subject: Reply with quote
I want to replace every part including the header so I know 100% that all the exhaust components are new and aren't going to start leaking soon after. right now there might be a leak somwhere that I can't find.
after that I'll get the rear hatch fixed so it seals up but I already sealed it up airtight with plsstic and still got CO reading in the car.
I said no to drugs but they wouldn't listen. Just kidding I don't do drugs.... well I used to smoke alot of pot but not anymore... Too busy with school now.
78 924 sold.
85.5 944
