electric fan question
Tom_in_LA
Guest
PostPosted: Sat Nov 02, 2002 3:17 am    Post subject: Reply with quote
I noticed this when replacing the radiator fans. The primary (driver side) fan and motor is slightly larger than the secondary, not by much, but a definite difference. My question is this, when does the secondary fan come on (I have factory air, if that'll help) ? I know there is only one thermo fan switch, and looking under the hood I see only the primary fan running at normal engine temp. Also, it makes me wonder, is sizing a cooling fan and motor such a precise science that Porsche couldn't make them the same size ? I'm sure it would be cheaper for the manufacturer (and consumer) if they were. Anyway, I'm just curious
PostPosted: Sat Nov 02, 2002 4:35 am    Post subject: Reply with quote
The different size could be caused by a different unit being used for a replacement.
The second fan will come on (or should) when the AC is switched on - it should force both fans on full-time.
Guest
PostPosted: Sat Nov 02, 2002 8:35 am    Post subject: Reply with quote
I do believe that you can replace the smaller motor with one of the big ones wont make that much difference, just mount the smaller blade on the new motor
Fast924Turbo
PostPosted: Wed Nov 06, 2002 1:06 am    Post subject: Reply with quote
You can also just replace those heavy fans with a lightweight aftermarket fan for like $100. But you'll only find them at that price on sale.
