tressone95 Guest
Posted: Sat Oct 19, 2002 8:10 am Post subject: |
ive heard that this problem can be fixed?
has anyone done this ?
thanks |
Lizard Guest
Posted: Sat Oct 19, 2002 8:43 am Post subject: |
yes check the FAQ or the Tech section but if not here is what I found
remove boot from shifter the pin that holds the shifter rod on gets stretched and causes looseness, also if you have the audi 4 speed (i don't know about the 5 speed) slide under the ass and look where the shifter rod attaches there is a nut holding it on and it can come loose if you tighten this up would be a good idea
tressone95 Guest
Posted: Sat Oct 19, 2002 10:38 am Post subject: |
uh..thats it?...i was under the asumption that needed a bunch of small parts?
Lizard Guest
Posted: Sun Oct 20, 2002 7:59 am Post subject: |
not from my experiance unless your bushing are toast and I havnt worked on those
Wiz-924 Guest
Posted: Sun Oct 20, 2002 9:03 am Post subject: |
| My Shifter (4spd) Does the same thing. I moves around alot even when its in gear. I dont think its a big problem. |
Wiz-924 Guest
Posted: Sun Oct 20, 2002 9:04 am Post subject: |
| My Shifter (4spd) Does the same thing. It moves around alot even when its in gear. I dont think its a big problem. |
Lizard Guest
Posted: Sun Oct 20, 2002 1:54 pm Post subject: |
with all shifters with that long of linkage there is expected to be alot of play, check under the shifter boot though and make sure that the pin that holds the shiftage on in not stretched or loosend, I actually had mine fall off, I replaced it with a bolt and tightened it up with some lock tight and made it so I can shift easily but is still tight
JvGinPDX Guest
Posted: Wed Oct 23, 2002 12:40 pm Post subject: |
| I have the 4 speed. which end is the shifter boot. Is it the shifter lever end, or is it where the long shift rod attaches to the transmission? My handle vibrates at engine speed, so it makes a rattle/buzz noise I want to get rid of. |
Smoothie Guest
Posted: Wed Oct 23, 2002 12:57 pm Post subject: |
| The shifter boot is up there with you in the passenger compartment at the bottom of the shifter handle. |
