Porschephile Guest
Posted: Mon Oct 14, 2002 7:30 am Post subject: |
Is there a way to fit 968/944 turbo brakes into the 924S 15 inch wheels?
afenn Guest
Posted: Mon Oct 14, 2002 10:28 am Post subject: |
Yes, and I believe that Powerhaus has adaptors so that you can install the black four piston brakes. Last months Porsche Excellence has an article on the conversion for a 944 but since it's the same equipment as the 924S it applies.
Porschephile Guest
Posted: Mon Oct 14, 2002 1:53 pm Post subject: |
great! thanks. that's the one with the 2 turbos on the cover right?
GP510 Guest
Posted: Tue Oct 15, 2002 7:31 am Post subject: |
I believe that the article you are talking about will only work with 16" wheels. I will have to check tonight.
Bart
1987 924S |
