Valve lapping and clearance adjusting screws concern.
coup85
PostPosted: Tue Apr 14, 2026 9:38 pm    Post subject: Valve lapping and clearance adjusting screws concern. Reply with quote
Doing a rebuild on my '79 924 2.0L. The head is at the machine shop right now and the machinist says everything looks mostly fine, but he wants to do a standard valve lapping.
My worry is the weird valve clearance adjustment on these engines. If they lap the valves, the valves will sit deeper in the head, which shrinks the clearance. I'm afraid I'll bottom out my stock adjusting screws when I try to set the valve lash later –does anyone know the adjustment margin the original ones have?
Has anyone gotten away with just lapping the original valves without needing to buy the thicker oversized screws?
924 - 79'
PostPosted: Tue Apr 14, 2026 11:24 pm    Post subject: Reply with quote
There are several classes of screws(indicated by the marking on the end), it might work, might bottom one out(be aware not to screw them to far, you could get around by swapping them around if you are lucky because often several of the types are present normally.
I have machined seats on two heads (one got new echaust valves though) and it mostly worked out, i think i swapped one or maybe two screws out. I think they can be bought new from porsche these days, but if you stumble over some cheap head its a good way to get spares like these screws.
coup85
PostPosted: Wed Apr 15, 2026 1:07 am    Post subject: Reply with quote
Thanks, the truth is I never did the valve clearance adjustment, and I'm a little unsure about how to get it right, I have the Haynes –and some videos, but I suppose there is nothing like just trying
I'll get the head back in a few days. I hope I can make it work. Someone just told me to just switch to shimmed cam followers. Seeing the price of those screws, if I need to change more than a couple of them, I might think about it.
924 - 79'
PostPosted: Wed Apr 15, 2026 3:19 am    Post subject: Reply with quote
The shimmed followers are great for racing - the stock followers are a liability at high revs thanks to the holes in the sides for the adjusters. But for street use, the stock ones are so much easier to adjust...
Doing the stock adjustment isn't such a big deal; I just redid them on my '82 931 the other day. Just measure and re-measure, and spin the motor over and measure again if you are worried...
PostPosted: Wed Apr 15, 2026 3:55 am    Post subject: Reply with quote
As Vaughan says, using shims in a race engine is a good thing. It saves weight (lifters are empty, without the heave standard adjuster screw) but requires removing the cam to change shims. Plus the 9mm shim kit (Alfa's use them) is expensive.
As Cedric says, there are 4 ranges of the factory adjustable screws. Lapping existing valves probably won't make much of a change in your engine. If you need to replace an adjustment screw, you will need to remove the cam from the head to, pull out the lifter, unscrew the adjuster from the side of the lifter and replace with another. Measure and adjust all eight several times before you decide whether you need to change one. That way, you might or might not have to remove the cam only once to change the adjustment screw range.
1981 924 Turbo sold
1982 924 Turbo sold
coup85
PostPosted: Wed Apr 15, 2026 4:13 pm    Post subject: Reply with quote
Thank you all. Noted on the followers; I'll remember to post the outcome in case anyone might find it helpful.
924 - 79'
safe
PostPosted: Thu Apr 16, 2026 2:44 am    Post subject: Reply with quote
Lapping valves usually takes away a miniscule amount of material, it's a polish. It the valves and seats are cut you actually takes away material, but its not a huge amount and the adjustors should be able to adjust for that.
And really if they need a cut, the alternative, running with leaky valves is not good....
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
Riggard
PostPosted: Fri Apr 17, 2026 4:20 am    Post subject: Reply with quote
a good rebuilder will measure the amount the valve stem protrudes before and after, and grind down the valve top to get the same distance after the lapping/grinding.
Raize
PostPosted: Sat Apr 18, 2026 2:10 am    Post subject: Reply with quote
I had a cracked follower and I never even exceeded the redline!
Will get solid ones if it happens again or if I run out of adjustment.
They only seem to need adjusted by 1 click every 10,000 miles anyway.
