Elektrobank
Joined: 19 Mar 2007 Posts: 149 Location: Pozzuoli,Napoli, Italy
Posted: Tue Aug 27, 2024 6:16 am Post subject: 951 rear arms on 931 g31 transmission |
Ho all!
I have a 1980 931 with g31 gearbox
Is It possibile to swap rear 951 aluminium arms?
Is It a straight swap?
At the Moment i have rear coilovers and no torsione bars
Anyone made this modify?
Thanks in Advance _________________ 924T Dta inj + sequential LPG
Cosworth
MotoMorini 501
Moto Morini 350 K2
lot of fun but always on foot.... |
Posted: Wed Aug 28, 2024 10:04 pm Post subject: |
You will find some of the answers in Ideolas old Performance Modifications thread.
I reinforced the upper brackets on my old race car as some of the 944 folks who had gone to coil overs felt it was necessary. I had the torsion bar +coil over system from GAZ. Unless you are a very good fabricator I think it is difficult to do well and the location of the brackets makes it more so. I had both the rear deck cut out and transmission out and and it was still a difficult location. _________________ Mike
'67 MG Midget Dp
Posted: Tue Dec 24, 2024 1:00 am Post subject: |
Like Mike said and here too. This might be helpful as well
The key is "early offset". This means the wheel mounts are closer to center of car or "sit in". Later offset 951 arms sit farther out for the wider width of the 944's
https://www.924board.org/viewtopic.php?t=31912&postdays=0&postorder=asc&start=75 _________________ 1980 931 since 1989
barnwerks
Joined: 28 Oct 2022 Posts: 40 Location: Northeast and southeast US
Posted: Tue Dec 24, 2024 9:26 am Post subject: |
| All 944 aluminum rear control arms are the same (early offset). The difference in offset beginning in 1987 is due to the projection of the hub. |
Elektrobank
Posted: Tue Dec 24, 2024 7:44 pm Post subject: |
I Hope the rear driveshaft Will fit, there Is no mention inside the ideola posts _________________ 924T Dta inj + sequential LPG
Cosworth
MotoMorini 501
Moto Morini 350 K2
madislandguy
Joined: 25 Nov 2009 Posts: 38 Location: Madeline Island, WI and Elburn IL
Britain
Joined: 26 Nov 2013 Posts: 303 Location: Cornelius, OR
Posted: Fri Jan 03, 2025 4:26 am Post subject: |
| The 951 arms will push the wheel out about 1" and will also require longer axles...but they are stock 944 axles so not too hard to find. It is because of the bearing width/drive flange length. |
Posted: Tue Feb 10, 2026 1:00 am Post subject: |
I love finding incorrect posts of mine and thinking it was a long time ago. No, it was 2024. My apologies
Here are the "tested" corrections"
Shortest Arms are the Steel version without wheel spacer. With Wheel Spacer they match the Early Offset Alum Arms With Early Hub
All 944/924S Aluminum arms are the same. The difference is in the hub installed in the arm, Early or Late
If you need extra fender clearance, use steel arms with custom spacer or no spacer _________________ 1980 931 since 1989
