Project-924-1979
Posted: Sun Dec 07, 2025 12:07 am Post subject: How do I clean my transmission casing? |
Hello everyone,
I'm currently in the middle of a transmission rebuild. which is costing a fortune, So i want transmission casing to show that it has undergone a rebuild of a qouple of thousand euro's, but I'm having a hard time cleaning it up.
I've been at it with paint thinners to remove the old paint the PO put on it. Then I spend a day with a dremel and a selection of wire brushes trying to clean it up, but I'm not fully satisfied. aluminium oxide that has build up over the years is quite hard to get of.
Do you guys have any suggestions?
 _________________ Restoring a late 1979 Porsche 924. This is my first car and my first attempt at restoring a car.
Learning a lot along the way and doing as much as I can myself. |
Posted: Sun Dec 07, 2025 2:06 am Post subject: |
I used dry ice blasting for my box, nice since it doesnt leave any residue, vapor blasting gives a really nice finish aswell _________________ 1980 924 Turbo
Posted: Sun Dec 07, 2025 6:40 am Post subject: |
Vapor honing (vapor blasting) cleans up the aluminum and makes it look like it just came out of the foundry. DO NOT glass bead it. _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
Joined: 10 Dec 2006 Posts: 981 Location: Noosa Heads QLD Australia
Posted: Sun Dec 07, 2025 9:41 pm Post subject: |
As above, vapour blasting and then clear coat for a lasting finish. _________________ 80/81 932/8 ROW |
safe
Posted: Mon Dec 08, 2025 8:04 am Post subject: |
vapor blasting (glass beads in water) gets aluminum really really nice. clean and sort of polished. Done it to parts on my BMW K100.
It doesn't embed the blasting media in the material, BUT, it gets into every corner and crevasse like crazy.
I would never do it on anything that holds oil. if I would, I would bolt it together so the water would only touch the exterior parts and still clean very well. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe |
