Camshaft duration
Karlio
PostPosted: Sat Sep 27, 2025 8:16 am    Post subject: Camshaft duration Reply with quote
What's your thoughts on camshaft duration and lift for an engine running 45mm itb's, fully programmable ecu, coil pack, exhaust headers.
290deg? 11.5mm lift?
PostPosted: Fri Oct 03, 2025 4:06 am    Post subject: Re: Camshaft duration Reply with quote
Whats the target rev range? Head flow characteristics/exhaust manifold/intake lenght/ target rpm should all play together with the cam
