Steering Rack
Raize
PostPosted: Mon Jan 26, 2026 3:40 am    Post subject: Steering Rack Reply with quote
Turns out my steering problem is the steering rack, not sticky top mount bearings. Wishful thinking. You can always safely assume the most expensive part has failed.
Thoughts on this pinion wear/damage? Haven’t managed to get the rack gear out yet. The preload was too tight so the rack was binding every half turn, I probably set it wrong.
[/list]
Raize
PostPosted: Fri Feb 13, 2026 10:17 pm    Post subject: Reply with quote
Jumped to conclusions, the rack is generally OK it's the lower steering shaft UJ that had corroded nearly solid in one direction.
I freed it off with some penetrating oil. Was thinking maybe I could flip the shaft 180 degrees so that the joint that's cooked at the bottom will now be at the top in a less harsh environment where I can also oil it easily, or is this just cope and a waste of time?
PostPosted: Fri Feb 13, 2026 11:37 pm    Post subject: Reply with quote
I'd be inclined, while you have it out, to simply see if you can source new joints to press in to your existing rack, it'll be much happier that way.
Not sure if those are available, but I thought I'd heard they were?
Raize
PostPosted: Sun Feb 15, 2026 4:02 am    Post subject: Reply with quote
If I can figure out what type of joints they are. They are pressed in and then the metal is peened to retain them.
It's also just a lengthened Vw Golf Mk1 steering shaft at the end of the day. Which cost about £40 new. You could maybe pull the ends off one of those and fit them to the 924 rod.
Or just cut it in half and weld a tube extension over it. It's an incredibly solid rod for what it does and I am sure with a good 5-6mm penetration bevel weld it would not be a weak point.
The car is still in pieces because my respray job turned into weld-a-thon and then winter happened so plenty of time to decide.
Raize
PostPosted: Sat Mar 07, 2026 5:49 am    Post subject: Reply with quote
Seems that the same 15x40mm universal joints have been used on the steering shaft of almost every vehicle for the past 50 years and they cost less than £10 so that's nice.
Getting the old joints out was very easy you just need a dremel with a square ended carbide bit to grind out the staking accurately and a vice and a socket to push out the bearings, the only thing I see potentially hard about putting the new ones in is there's no depth stop so you have to be careful not to bind the joint when installing it or staking it with a chisel.
The needle rollers were corroded solid in one side of the joint I removed.
