gml
Joined: 04 Mar 2021 Posts: 133 Location: Ontario Canada
Posted: Mon Jun 16, 2025 1:38 am Post subject: "While you're in there" jobs with coolant drained |
I'm replacing the coolant expansion tank so I'll be draining the system. I have a new water pump and v-belt as well which I'll install.
Any other jobs that I should do while the coolant is drained out of the system? _________________ George
1982 924 NA 5-speed |
Joined: 29 Jul 2001 Posts: 9070 Location: Royal Oak, MI, USA
Posted: Mon Jun 16, 2025 3:41 am Post subject: |
Thermostat would seem like an obvious one, if you don't know when last replaced.
Could also consider having the rad itself cleaned, pressure tested... _________________ Vaughan Scott
Raize
Posted: Wed Jun 18, 2025 2:53 am Post subject: |
If your heater controls don't work it could be an opportunity to replace/free up that valve.
And it's an opportunity in general to replace any hoses that are really suspect. |
chuck21401
Joined: 20 Feb 2005 Posts: 606 Location: Annapolis, MD
Posted: Fri Jun 20, 2025 12:18 am Post subject: |
Probably not a concern with 924NA but in my car I drained the system to install lower temp fan switch and new thermostat. _________________ 1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler |
Beartooth
Posted: Fri Jun 20, 2025 4:28 am Post subject: |
+1 on having the radiator checked over and boiled out. You may want to have it rodded out, depending on what they find (not an automatic though: it could be pretty clear if coolant services were kept up on). Mine was half-blocked - not surprising given the level of neglect, and I doubt it would have cooled adequately. Also, like Raize said, least look over the hoses if you're uncertain on them: originals are definitely a liability, but you might not be able to replace them all. _________________ 1980 931 diamond in the rough |
