Fuel pump relay problem on a 924 base model 1984
nuno almeida
PostPosted: Sun Jun 15, 2025 6:31 am    Post subject: Fuel pump relay problem on a 924 base model 1984 Reply with quote
Can anyone tell me where the wire that connects to 31b on the fuel pump relay goes? I think it goes to the ignition module, I'm just asking to be sure.
coup85
PostPosted: Sun Jun 15, 2025 6:49 am    Post subject: Reply with quote
Not sure if this helps:
924 - 79'
nuno almeida
PostPosted: Sun Jun 15, 2025 6:53 am    Post subject: Reply with quote
What does the "1" mean? Do you have the legend?
coup85
PostPosted: Sun Jun 15, 2025 7:40 am    Post subject: Reply with quote
I'm afraid I can't find it in the Haynes manual, unless it is the same as in the 79' model:
924 - 79'
PostPosted: Sun Jun 15, 2025 9:05 pm    Post subject: Reply with quote
Yeah, that'd be the ground location, and I expect the answer is the same across the years, grounding near the relay board.
nuno almeida
PostPosted: Tue Jun 17, 2025 12:21 am    Post subject: Reply with quote
didnt help that much ahhaha, but thank you anyways!!
