Crank bolt removal
bureau13
PostPosted: Sun Jun 01, 2025 2:03 pm    Post subject: Crank bolt removal Reply with quote
I am converting my car ('82 931) to EFI and one of the steps involves replacing the crank pulley. Only, I can't get the crank bolt off. To add to my frustration, I have removed it before, a few years ago. I just don't remember how.
On my 928, it's easy, just bolt in the flywheel lock and have at it. However, I can't seem to fine a flywheel lock anywhere. I saw a thread where someone was alleging that a 944 lock would work but no confirmation, and I'm skeptical.
I have blocked the rear wheels (both sides) and put the car in gear (tried both 1st and 5th) but the motor still turns far too easily.
I saw someone recommend pulling a wire off the coil and using the starter but...first, I no longer have any of that stuff installed, and second, I already have PTSD from the last time when I was reinstalling the crank bolt, left the wrench in place like an idiot and several thousand curse words later I was replacing the head. So I'd prefer not to go down that route.
1986.5 Silver 928S
2008 Volvo XC90 (Daily)
Past lives (I miss them all):
2007 Hummer H3 (Timing chain guide failure)
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen)
PostPosted: Sun Jun 01, 2025 10:36 pm    Post subject: Reply with quote
You dont need to remove the central bolt in order to replace the pulley.
Just those 6 allen key bolts.
bureau13
PostPosted: Mon Jun 02, 2025 12:15 am    Post subject: Reply with quote
Glad I asked, damn...I just assumed the crank bolt had to come out. Doh!
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
