No Spark in my 81 Weissach Edition
Mclaren924
PostPosted: Tue May 13, 2025 3:38 am    Post subject: No Spark in my 81 Weissach Edition Reply with quote
Hey guys need somebody with experience to chime in here, trying to help a buddy get his 81 weissach back to running again and just realizing now that his car has a completely different ignition module and a 3 pin distributor compared to the 77-80 cars I'm used to seeing. Tried going thru the PET to sort out what's what but there's little to be found if it truly belongs in 1981 NA. The ignition module has a part number starting 477 905, which leads me to believe somebody may have grafted in a later model turbo ignition module and potentially more. I am just going off photos from my buddy so I will try and get the full part number off it. I may be completely off track and this just may be the way 81 924's were setup but that's the point of this post is for hopefully somebody with experience in the later cars can set me straight. Thanks if you read my incoherent rambling this far.
1980 931 "Salt" Bucket wannabe racer (Dreaming)
1977 924 Slicktop "Pennie"-Most likely parts
1979 3/5 gt clone 924- Shop Test Car
PostPosted: Tue May 13, 2025 9:33 pm    Post subject: Reply with quote
Well, the late Turbo distributor has NO leads, so not sure that's entirely right...
I'd wonder if maybe it has a Euro NA setup?
Is the ignition module maybe really small, barely bigger than a matchbook, on an aluminum heat sink?
Mclaren924
PostPosted: Wed May 14, 2025 2:37 am    Post subject: Reply with quote
It's a little black box mounted in the same location as the standard 77-80 ones but its roughly half the size, it does appear to be mounted on some solid block of metal as well. Would assume it's a heatsink but photo isn't great. It could be a eruo setup, It wouldn't be the most impossible thing to believe. The connector for his wiring harness to the Ignition module doesn't come back in the 80-85 PET so I'm wondering if it is EURO stuff. Would the euro parts not be in my version of the PET, I'm assuming there's different versions for ROW cars hmmmm.
Raize
PostPosted: Wed May 14, 2025 2:52 am    Post subject: Reply with quote
My Haynes Manual has a bit about this at the end, it's a TCI-H Hall Effect ignition system. As well as that control unit there should be an idle stabiliser unit somewhere.
Anyway the main question is, does it spark? All of these things are basically black boxes anyway.
Mclaren924
PostPosted: Wed May 14, 2025 3:04 am    Post subject: Reply with quote
No spark to the coil at all is the main problem, cars 4000 miles away from me so I'm trying my best to put this guy on the right path. He's done a lot of parts shotgunning and un-surprisingly it hasn't fixed it. I told him to check his coil negative and positive leads as they are resistor wires and will mess the whole system up if not working correctly. Then trace all the wires back to the ignition module and make sure it's getting power. That leads us to here, he's telling me that he's tested the ignition module and says it's dead. My problem here is I'm doubting if he correctly tested it and if it is actually dead, finding a replacement because the actual PN on it is telling me its off a turbo which I also have my doubts about. If the systems all factory as should be then im not too worried about him testing it incorrectly, was mainly worried somebody Frankenstein it and now he's using the wrong test or wiring diagram or pinout to ascertain ignition modules health.
Mclaren924
PostPosted: Wed May 14, 2025 3:06 am    Post subject: Reply with quote
https://imgur.com/a/PQpHSLy
Posting photos has always been the bane of my existence lol.
Raize
PostPosted: Wed May 14, 2025 3:14 am    Post subject: Reply with quote
https://imgur.com/a/yWfu2Z2
I think it’s this. The wire colours match. Looks like this type doesn't use resistor wires.
It's really not a hard circuit to check. Is there any voltage at coil terminal 15? Plug A12 burned out on my car at the fuse box and I had to bypass it.
PostPosted: Wed May 14, 2025 3:16 am    Post subject: Reply with quote
Oh yeah, that looks like what was on my '82 931 before I 'Squirted it.
https://www.fcpeuro.com/products/audi-vw-ignition-control-module-febi-191905351b
Factory parts manual says it's 81-82 NA AND Turbo.
PostPosted: Wed May 14, 2025 4:05 am    Post subject: Reply with quote
More into the details... from the '81 924/924 Turbo Service Information booklet.
On the NA, the new style transistorized ignition unit is fired by the Hall effect sensor in the distributor (and the unobtanium flywheel sensor on the Turbo).
The additional black box stacked on the smaller ignition unit is the idle stabilizer.
From the manual - Checking Operation:
Connect a voltmeter or a test lamp between ignition coil terminal 15 and ground. Start engine and observe volt meter or test lamp.
If volt meter needle pulsates or test lamp flickers, the Hall sender and control unit are probably OK.
Also, the idle stabilizer can be switched off (to adjust mixture/CO level and idle speed adjustments) by disconnecting the connector between the throttle switch and the ignition control unit. This plug is accessible in the engine compartment on the left wheel housing (in the harness right by and leading to the ignition unit on the fender).
Much better detail in the full manual, starting on page 28-33:
The ignition stabilizer can be completely bypassed for diagnostic purposes by disconnecting its two leads and plugging them together.
Beyond that... really should step through the manual, with voltmeter in hand, step by step.
Mclaren924
PostPosted: Wed May 14, 2025 5:19 am    Post subject: Reply with quote
Thank you Raize and 924Racr, you guys saved me a lot of time with this. I have the FSM so I will dig through and check out the sections you mentioned. Had a feeling I was just overthinking this. Have already forwarded your message to my friend in PA and he will start trying that while I read up more on how the system actually works. Will post back here when we get to the bottom of the issue. Cheers lads
Mclaren924
PostPosted: Wed Aug 13, 2025 11:30 am    Post subject: Reply with quote
Alright Vaughn I'm here to pick your brain.
This car has been driving me #### crazy, I almost tried to burn it down I got so mad (half joking).
I have verified the coil is ohming out correctly and moved onto the next section of the diagnosis. For a little bit today (30 min to an hour randomly) I was actually getting 4 volts or so across terminals 1 and 15 when the starter was bumped. Hooked up a test light and it was flickering the light every time starter was energized.
This didn't happen last week when messing with this car and after about an hour i lost all power across the coil again and now I'm not even getting 12v on the green.
I started digging around behind fuse box and found a weird loose wire so I went to pull it so I could see where it went and it instantly lit up like a christmas tree. Glowing bright Orange and smoke everywhere. Thankfully was able to get it to stop shorting out and vent out the smoke, really thought the car was a goner and the whole shop for that matter for a second or two. Really scary how hot and how volatile that got in less than 5 seconds.
Wa able to pull fuse box forward and explore what happened. It appears that the number 31 wire/pin on the fuel pump relay had been replaced by somebody and they used a large chunk of unsleeved wire and it brushed up against a live and rest is history. Thankfully it doesn't appear to have ruined anything else other than my shorts but now I have some questions.
Does that pin 31 ground wire just go to the big ground tree with all the other ground spades behind the dash?
Second question, which I'm fairly certain I know the answer to. Could pin 31 having a faulty ground cause my issues at the coil?
currently have zero ambition to continue messing with this car so going to give it a day or so and hopefully get set straight by you kind gents. I'm feeling like it has to be a damaged wire or pin somewhere as we have put in a new Ignition Module too.
Normally can get by without hand holding but may need both hands held for this one lol.
