Speedometer reads 10% slow
stumo72
PostPosted: Tue Mar 18, 2025 7:12 pm    Post subject: Speedometer reads 10% slow Reply with quote
Hi All
My 924 speedometer reads exactly 10% slow
20 Speedo - GPS says 22
50 - 55
70 - 77 and so on.
The speedo runs perfectly, no wobble or noise. Tyres are original size fitment for the car.
Does anyone have any thoughts on where I should be looking?
Could someone have changed something in the past? (I am aware of different gears for the odometer, but not sure how the speedometer can be changed for speed?)
Could the gauge just be faulty?
Thanks!
PostPosted: Tue Mar 18, 2025 8:08 pm    Post subject: Reply with quote
What tire size are you running?
stumo72
PostPosted: Tue Mar 18, 2025 11:30 pm    Post subject: Reply with quote
185 x 70 x 14 on the stock rims. I believe that is stock tyre size.
Kenodog
PostPosted: Wed Mar 19, 2025 1:41 am    Post subject: Reply with quote
Just drive 10% faster...
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
stumo72
PostPosted: Wed Mar 19, 2025 2:36 am    Post subject: Reply with quote
'And that, you see, is why I was speeding M'lord'
PostPosted: Wed Mar 19, 2025 2:48 am    Post subject: Reply with quote
The 10% rule is more or less the same for most cars.
Speedo will always show a bit more than it actually is.
stumo72
PostPosted: Wed Mar 19, 2025 4:25 am    Post subject: Reply with quote
This is less by exactly 10%.
scm924s
PostPosted: Thu Mar 20, 2025 11:56 pm    Post subject: Reply with quote
Check that the LH front hub grease cap is tight on the hub, the speedo cable is driven by this and can affect the speedo reading if it slips
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
Beartooth
PostPosted: Fri Mar 21, 2025 4:19 am    Post subject: Reply with quote
I monkeyed with the needle on mine when I had it apart to fix the odometer gear slipping on the shaft, aiming to have it read accurately at 60. I got it pretty close at highway speed, but it's off at significantly slower or faster speeds. This is with 195/65/15 tires. 185/70/14 seems to have been originally spec'd, according to the 924.org tech section. But there are a few other sizes. How does the odometer read? If it's high too, dropping to 185/65 or maybe even 195/60 tires might be worth a try (and have the same effect as gearing down - not sure if you'd want that or not). Ultimately though, I doubt you have a mechanical problem: mechanical speedometers have more error (and can get worse over time), and they're skewed to read high by design because driving slower than you think you are is the safer choice for a manufacturer.
1980 931 diamond in the rough
