bureau13
Joined: 07 Sep 2017 Posts: 495 Location: South Florida
Posted: Mon Mar 03, 2025 1:47 am Post subject: Front turn signal (but not parking lamp!) doesn't work |
I started getting the fast blink when signaling a right turn, and it turned out to be the front signal that was bad. I got another bulb, put it in there and...no change. I swapped the good bulb from the other side over to the bad side, just in case, and also nothing. However, when I turn on the headlights, the "parking light" or whatever you call it, which uses the same bulb as the turn signal, lights up as it should.
Any idea what has gone bad? I believe a single relay controls the turn signal blinking, and that seems to be working properly with the exception of the one bulb. _________________ 1982 931
1986.5 Silver 928S
2008 Volvo XC90 (Daily)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen) |
