carburetor convertion Weber 40 DCOE
stuartmcleanprojects
PostPosted: Tue Jan 21, 2025 2:58 pm    Post subject: carburetor convertion Weber 40 DCOE Reply with quote
Hi, I have a 2l 924 and have removed the injection system and replaced with Weber carbs. The engine did run but seems to be only on 2 cylinders or timing timing is out can anyone please assist with the possible issues or has anyone done a similar conversion?
Stuart
PostPosted: Wed Jan 22, 2025 1:08 am    Post subject: Reply with quote
I cant help with the carbs, i think there are fewer and fewer people around that know carbs. This is one important aspect why one should not convert to carbs nowadays as you are dependent on knowhow, parts and people that are dissapearing. Same is valid for the k-jet.
If you cant figure it out and you cant get it to work properly, you can buy an EFI and a supercharger kit from me and noy only the car will work properly every time and in every condition, also thr technology and knowhow required to maintain the EFI system is a modern and available one.
