bureau13
Joined: 07 Sep 2017 Posts: 487 Location: South Florida
Posted: Mon Jan 13, 2025 8:51 am Post subject: Fuel line in to distributor not sealing |
I made the mistake of disconnecting the fuel in line at the distributor banjo bolt, thinking I had the adapters to connect to a fuel pressure gauge, but I did not. Now I keep seeping fuel even though I've tried several sets of copper washers. I think that's an M12 fitting. Anyone have the specs on the required washers? Maybe mine are too thin.
It's a 1982 Turbo, although I suspect they are all the same in this area. _________________ -----------------------------------------
1982 931
1986.5 Silver 928S
2007 Hummer H3 (Daily Driver)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen) |
Raize
Posted: Mon Jan 13, 2025 8:55 pm Post subject: |
I ended up using Dowty washers on mine. Must have tried to get it to seal with the copper ones at least a dozen times with no luck. |
Posted: Mon Jan 13, 2025 9:06 pm Post subject: |
I couldn't get the FD stop leaking with my generic copper washers. Bought them from Porsche and it didn't leak a drop. The dimensions and material differed a bit, obviously enough:) _________________ 1980 924 Turbo
Posted: Mon Jan 13, 2025 9:34 pm Post subject: |
Yeah the copper washer used for fuel sealing have a soft outer layer that does the sealing.
You can id them by their edge bevel/radius. The regular ones have sharp edges.
 _________________ Supercharger and EFI kits
https://www.the924.com |
Joined: 08 Jun 2010 Posts: 1243 Location: Maysville, Colorado
Posted: Tue Jan 14, 2025 1:36 am Post subject: |
You could try taking out the washer and then heating it very hot with a propane torch. It would take out any work hardening, ie the copper would be softer after cooling. _________________ Mike
'67 MG Midget Dp
bureau13
Posted: Tue Jan 14, 2025 8:01 am Post subject: |
Thanks for the info. I ordered a new set that claims to specifically be for this purpose, so we will see it that works. _________________ -----------------------------------------
1982 931
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
!tom
Posted: Fri Jan 17, 2025 6:22 am Post subject: |
I think it's important to quench the heated copper to anneal it so that it is soft enough to seal.
Heat washer hot with torch, then dunk in water. Should be able to re-use after that process. _________________ 78 924 NA
5-lug |
bureau13
Posted: Sun Jan 19, 2025 2:03 am Post subject: |
For what it's worth, I just bought a new pack of washers and made sure they specifically claimed to be crush washers for sealing. I don't know if the other ones were NOT intended for that, were just crap, or I got lucky, but the new set worked perfectly first try. _________________ -----------------------------------------
1982 931
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
