Removing the internal door release?
924-UK
PostPosted: Sat Feb 10, 2024 3:35 am    Post subject: Removing the internal door release? Reply with quote
I've undone all the screws and clips etc. but I am left with the handle holding it onto the door. I read there was a screw if you lifted the handle bit but there isn't on my '84 NA 924?
This is my handle...
And if I lift the handle bit ...
Anyone had the same issue?
'84 924 2.0 NA
Riggard
PostPosted: Sat Feb 10, 2024 7:19 am    Post subject: Reply with quote
yup, you have to pry that cup out, behind it is the screw
924-UK
PostPosted: Mon Feb 12, 2024 12:33 am    Post subject: Reply with quote
Thanks. I see it now. I was trying to pry the outer casing off!
I've added a photo in case it helps anyone else.
'84 924 2.0 NA
Riggard
PostPosted: Mon Feb 19, 2024 5:14 am    Post subject: Reply with quote
Cool! it's something you really have to be aware of... they hid it pretty well. Also struggled with it the first time. Once you know... its easy.
