924 Ignition Coil No Power After Cranking
JamiEngland
PostPosted: Tue Feb 06, 2024 5:48 am    Post subject: 924 Ignition Coil No Power After Cranking Reply with quote
Hi, having an issue getting the car to run. Ran fine before removing the dash (got a couple of wiring gremlins to figure out).
Now the car will start while cranking, but not when the key is in the running position. This says to me that the coil isn't getting power while in the running position, I validated this as the car runs with a direct 12v feed from the battery.
The question I have is why, there doesn't seem to be 12v from the back of the relay box all of the time but I believe there's some kl15 issues with the car as I can intermittently get 12v on A12 at the fuse box (there's some strange repairs in the fuse box)
Along with this did all cars come with ballast resistors? The only resistor I have found in the car is the large one by the fuse box, but I assume this is for the blower fan. I am unable to measure any resistance between the transistor module and the coil, but I believe there should be a 1 Ohm resistor there. Cheers
!tom
PostPosted: Wed Feb 07, 2024 3:54 am    Post subject: Reply with quote
There are several significantly different wiring diagrams for the car over the years.
People will need to know the year in order to provide more definitive assistance.
78 924 NA
5-lug
PostPosted: Thu Feb 08, 2024 1:10 am    Post subject: Reply with quote
Ignition switch commonly fails on these, causes this issue...
JamiEngland
PostPosted: Thu Feb 08, 2024 8:03 am    Post subject: Reply with quote
[quote="!tom"]There are several significantly different wiring diagrams for the car over the years.
People will need to know the year in order to provide more definitive assistance.[/quote]
Sorry should've mentioned, it's an '85 2.0 non turbo auto
