Postcard from Ireland...No spark, no go.
GT_Cork
PostPosted: Sun Jun 18, 2023 9:46 pm    Post subject: Postcard from Ireland...No spark, no go. Reply with quote
Hi all,
I've searched and searched, but am just completely stuck.
I have a 1983 2.0 car into which I've placed a 1985 2.0 harness. The original harness was hacked to bits, and there was just no point starting with it so I took it off a long term project.
The issue now is that with the harness in, the car won't start. I've narrowed it down to no spark. I have replaced the coil, the dizzy and lots of other parts but I'm still back to a car that's happy to crank, but not happy to fire.
Last week, if I jumped the + of the coil directly from the battery, the car would run...but now that makes no difference what-so-ever.
As I have good voltage to + of the coil, I'm wondering if it's my Ignition Control Module. I have a spare one which I've tested, but that has made no difference.
Anyway, there's lots of posts here about no fuel but having a no spark condition that isn't solved by replacing the coil/plugs/leads etc is comparatively rare.
So, in utter frustration I'm at a loss. Any ideas?
Mclaren924
PostPosted: Mon Jun 19, 2023 12:33 pm    Post subject: Reply with quote
Do you have plugs in the correct order and the dizzy set correctly? Correctly gapped spark plugs? Start with all the small stuff you think is good and check again, likely something small along the way slipped by unnoticed and is now causing pain.
1979 3/5 gt clone 924- Shop Test Car
ChrisMadge
PostPosted: Mon Jun 19, 2023 7:28 pm    Post subject: Reply with quote
connected the green wire to the dizzy ?
1984 MY 924 2.0 NA
1975 MG Midget
GT_Cork
PostPosted: Mon Jun 19, 2023 7:42 pm    Post subject: Reply with quote
So;
Timing is set at the cam, crank and flywheel.
Dizzy has arm pointed at the slot and 1,3,4,2 is the plug order off the cap to the engine.
Power to the coil, and lead plugged in to dizzy.
When I turn it over the FPR kicks into action.
Only thing I’m wondering about is the connection of the ignition switch to the ICM-I had a situation with no FPR kicking in when cranking which was fixed by fiddling with the ignition switch.
GT_Cork
PostPosted: Tue Jun 20, 2023 6:45 am    Post subject: Reply with quote
I put a new ignition switch in today…The key is now doing what it should do (FPR kicks in when cranking etc) It even fired up, but was running badly. Went to move the distributor to get it running a bit better and it just died…unable to replicate poor running.
