Front Suspension Question
Glemon
PostPosted: Tue May 30, 2023 4:10 am    Post subject: Front Suspension Question Reply with quote
The front lower a-arms bushing (the cheap round one). Is the inner metal tube supposed to turn with the suspension, or is it supposed to be locked in and suspension pivots on rubber flex? Do I tighten the retaining bolt to snug or to the point of keeping it from moving at all? Thanks.
88 924S
68 TR250
02 IS300
Beartooth
PostPosted: Tue May 30, 2023 4:31 am    Post subject: Reply with quote
The inner metal bushing should be clamped tight. There might be exceptions, but every rubber bushing like that I've seen holds the inner bushing tight and the rubber absorbs the twist. Along with that, it's best to have the vehicle sitting at ride height when you torque the bolt, if possible. If you torque it with the suspension unloaded, the bushing will be twisted at rest and may wear more quickly.
1980 931 diamond in the rough
Glemon
PostPosted: Tue May 30, 2023 4:36 am    Post subject: Reply with quote
Thanks, that is exactly what I needed to know. I retorqued them with the car sitting at normal resting height.
88 924S
68 TR250
02 IS300
