WWWHHHHHOOOOOOSSSSSSHHHHHHHHH!!!!!!
emoore924
PostPosted: Thu Oct 23, 2008 3:27 am    Post subject: WWWHHHHHOOOOOOSSSSSSHHHHHHHHH!!!!!! Reply with quote
Ok, that's what happens when I remove my fuel cap after a stint of hard driving. There is considerable pressure within the tank, so much so that if I don't hold onto the cap tight when I'm removing it, it would blow right out of my hands. This outgassing continues on for about 15 seconds at a decreasing rate (almost sounds like the fuel is boiling in the tank when the pressure is released...). Also, not sure of the relevance of this fact but the last time it did this, the engine died immediately when I removed the cap. I can also hear the fuel tank going ka-thunk! as it pops back into shape once the pressure is relieved. It happens every time if the car is hot when driven hard. So, not an intermitant problem, and it has been doing same more or less for years...
1979 n/a. Runs fine. Fuel pump is starting to make a little noise however, but I'm not sure that has anything to do with this. Might be a simple coincidence.
Ok, so why so much internal pressure within the fuel system and tank? Is this normal or not?
If not, what do I need to do to remedy?
DOCO
PostPosted: Thu Oct 23, 2008 3:39 am    Post subject: Reply with quote
tank vent is plugged most cars vent through the gas cap.not really sure about the porsche though .gures please
Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR"
Your tank vent is plugged. If left to go for too long, it could collapse the tank.
PostPosted: Thu Oct 23, 2008 3:54 am    Post subject: Reply with quote
Sounds severe.
I'd check the EEC system. It's shown in the Haynes. There's a safety valve that should open at a certain level to relieve pressure from the tank. That flow from the pressure relief should go forward to the charcoal canister or to the engine when it's running and warmed-up and at part throttle. -So there are a few components there to check, but my prime suspect would be the safety valve - it may be stuck shut (, but don't ask me where it is). Another possibility would be the charcoal canister vent being clogged, but then the pressure should still be getting relieved when the EEC control valve opens (when running, warmed and at part throttle).
PostPosted: Thu Oct 23, 2008 4:25 am    Post subject: Reply with quote
Ed, once you identify the problem, if it can't be repaired, I may have spares of the components you need...let me know.
emoore924
PostPosted: Thu Oct 23, 2008 5:04 am    Post subject: Reply with quote
EEC = ??
!tom
PostPosted: Thu Oct 23, 2008 5:07 am    Post subject: Reply with quote
Evaporative Emissions Control
78 924 NA
5-lug
Brockoli
PostPosted: Thu Oct 23, 2008 5:10 am    Post subject: Reply with quote
EEC = evaporative emission control
its a system that sends gas tank fumes+crank case fumes to your air box to be burnt in the engine.
Do all 924's have this much pressure in the gas tank. Mine does this too, but at the last couple fills it hasnt. Mine doesnt make the gas tank deform tho.
emoore924
PostPosted: Thu Oct 23, 2008 5:15 am    Post subject: Reply with quote
EEC, got it.
I think the problem might be that the EEC pressure relief valve only operates when the car is warmed up and at PARTIAL THROTTLE.
I only operate the car at FULL THROTTLE
I'll check it out...
Ozzie
PostPosted: Thu Oct 23, 2008 7:14 am    Post subject: Reply with quote
Not sure if its the same for US cars but there is pressure valves next to the filler hose on mine. Have to remove the cover on the RH side for access.
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Thu Oct 23, 2008 10:33 am    Post subject: Reply with quote
I think you may have combined 2 different parts into one. The system includes both an EEC control valve (this one's in the engine compartment), and a safety/pressure relief valve (likely located where Ozzie described) - so 2 different parts..
924guy
PostPosted: Thu Oct 23, 2008 1:02 pm    Post subject: Reply with quote
try looking at p/n 810201106a "bleeder valve", there is also a "shutoff valve" which looks very similar, in the same assembly. should be located in , or near the fuel delivery pipe housing, attached inline to vent hoses. if this, or its equivelent is blocked or missing, it will cause the problem you describe. looks like an oversized vacuum valve (acorn.)
I can take a picture of a real one if you need, but its in the 84' 944..earlier may or may not be different, and i for some reason i cant snip a pic from adobe pdf's anymore, guess id better install the full version again..
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
PostPosted: Thu Oct 23, 2008 1:04 pm    Post subject: Reply with quote
Again, I have extras of those that I salvaged from a couple of cars, so if you need one, let me know.
PostPosted: Fri Oct 24, 2008 3:42 am    Post subject: Reply with quote
I though on the early cars there was a vent built in the the filler neck that runs from the tank to the gas door connected with a rubber boot and clamps off the neck runes a vent line... am i right.
gwan2cruz
PostPosted: Fri Jul 08, 2022 7:42 am    Post subject: WWWHHHHHOOOOOOSSSSSSHHHHHHHHH!!!!!! Reply with quote
My 1978 924 is a n/a engine and I am having the same problem with lots of pressure when I remove the gas cap after driving. I know the bleeder valve is no longer available so can I just remove the valve and put in a direct line to the canister?
Thank you.
78 924 Special Edition
