77 and 80 na differences and Conrod bearings
Mclaren924
PostPosted: Sat Sep 17, 2022 2:48 am    Post subject: 77 and 80 na differences and Conrod bearings Reply with quote
I plan to swap an assembled short block out of a 1980 924 into a early 1977 with a bad bottom end but good head. Am I going to run into any weird issues with the HG or accessory mounting issues? With that said I've got at least two motors I plan on rebuilding and was wondering if mittlemotor is really the only place left to get stock conrod bearings...Will likely end up reusing originals if that's the case.
Cheers
Karlio
PostPosted: Sat Sep 17, 2022 6:29 am    Post subject: Reply with quote
I have new manufactured con rod bearings in stock, am in UK but will ship world wide. £62 plus postage.
I also have main crankshaft bearings, Inlet and exhaust valves and 87.5mm pistons also in stock
Cheers karl
PostPosted: Sat Sep 17, 2022 6:50 am    Post subject: Reply with quote
If the cranks need ground and they should at least be polished, the last time I talked to EBS Racing they had the first undersize connecting rod bearings as well as the Chinese main bearings. Hope that helps. I also have a set of the second undersize (.5) that I found cheap on ebay a while back.
Mike
'67 MG Midget Dp
PostPosted: Sat Sep 17, 2022 3:08 pm    Post subject: Reply with quote
Cheers karl
Excellent offer, so tempting to build a stroker 924.
Would you be able to build new custom cranks or modify old ones?
Mclaren924
PostPosted: Sun Sep 18, 2022 2:26 am    Post subject: Reply with quote
Cheers karl
I sent you a PM about ordering some things Karlio, in the same thought as morghen as well though. Could you do a stroker kit? I have one build I plan on giving all the beans too and have been pondering a higher displacement setup. Cheers
Malcolm
