Smoke at hot idle
Stu2j
PostPosted: Tue Oct 01, 2002 1:04 am    Post subject: Reply with quote
OK
82 924 (non turbo) has white smoke from the exhaust during a hot idle. Nothing from the exhaust when cold and/or warm nor is it noticable while driving.
Is it time for a rebuild or might there be a simpler explanation?
Thanks for any opinions.
AznDrgn
PostPosted: Tue Oct 01, 2002 3:59 am    Post subject: Reply with quote
white smoke is a sign of water in the system. How does your oil look? I reccomend running a compression test and see if anything is leaking, then post the results and we can go from there.
