Driver's Side Rear lights out
kyudroid
PostPosted: Fri Jun 17, 2022 2:03 pm    Post subject: Driver's Side Rear lights out Reply with quote
I just acquired a 1987 924S. The rear blinker and brake lights are out on the driver's side. So is the third brake light. I cleaned and replaced the fuses. Continuity across them at the fusebiox. Bulbs are good. Contact are good based on continuity tester. The grounding is good and the parking light works.
The sockets are not getting voltage when it should be on.
Any ideas why they aren't working?
1979 924
