Rear head area oil leak
MikeDanger
PostPosted: Wed Dec 29, 2021 2:51 pm    Post subject: Rear head area oil leak Reply with quote
I have a bit of leakage coming from the back of the head. can't exactly tell where as the Distributor housing had a full coating of oil and dirt.
What are the usual leakage points? The joint between the Dist and the housing looked wet, but theres no O-ring on these.
I think I replaced the Valve cover gaskets?
PostPosted: Wed Dec 29, 2021 10:21 pm    Post subject: Reply with quote
Ah, so many spots - not the best part of the design. Yes, the back corners of the valve cover gasket is possible, also the distributor housing as it bolts to the head... but also the distributor itself where it slips into that housing, should have a round paper gasket that's pretty weak. But the biggest most likely is the oil pressure sender port... since it's under pressure, unlike all the rest (excepting crankcase pressure)...
PostPosted: Wed Dec 29, 2021 11:39 pm    Post subject: Reply with quote
Agreed. I have had to remove it, clean the threads and reinstall. Permatex makes a Hydraulic/Pneumatic sealant that works well on the threads. It takes a spray cleaner also. Its a copy of some stuff made by 3M and Locktite. Traveling so not sure but it might be #8514. Take a wrench of the right size(17mm?) and cut it down to about 3" long. Its not a fun job. One time I just took the distributor out and mad it much easier.
Mike
'67 MG Midget Dp
PostPosted: Thu Dec 30, 2021 11:43 pm    Post subject: Reply with quote
Agree with the gents above. Just pull the dissy and seal everything unless you can definitively identify where the leak is.
PostPosted: Fri Dec 31, 2021 3:38 am    Post subject: Reply with quote
I've had a leak straight out of the oil sender spade
MikeDanger
PostPosted: Sat Jan 01, 2022 7:33 am    Post subject: Reply with quote
I used some grey rtv on the distributor, but i dont see how to get to, the OPS cant even get my hand back there
