Transmission sounds odd.
chris78
PostPosted: Sun Sep 29, 2002 5:52 am    Post subject: Reply with quote
When ever I push in the clutch there is a odd sound coming from the engine. I know this is not normal. Have any suggestions???
dpw928
PostPosted: Sun Sep 29, 2002 6:47 am    Post subject: Reply with quote
It sounds like the throwout bearing is going out. Check to make sure the springs that hold it to the yoke haven't come loose and check to make sure the bolts holding the bellhousing to the block are tight. If those check out and it is the throwout bearing replace it before it locks and tears up the pressure plate.
Dennis
