stan_5150
Posted: Sat Sep 04, 2021 2:36 am Post subject: Master Brake Cylinder - pressure switch leaks |
I'm in the process of bench bleeding my master brake cylinder after it's been reworked, and I have fluid leaking from the brake light pressure switches. I removed them before I sent the unit to the shop, and I don't recall any o-rings or washers installed prior.
Edit: after I had noticed the leaking I removed and sanded them to try and remove any debris.
Has anyone else run into this issue? If so, what was your fix? TIA _________________ 1978 924 N/A |
kondzi
Posted: Sat Sep 04, 2021 5:22 am Post subject: |
Add a Copper washer? Brake system has huge pressures. Usually sealed by tapered bolts or so. Check the hole / sensor if they can seal to each other. Maybe inside on the sealing face there is a small crack. _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
