MikeDanger
Posted: Sun May 23, 2021 8:12 am Post subject: What is killing my Tachs? |
WTF is going on here?
So I had 2 tachs go bad....Ok I guess thats possible, I had a buddy give me 2 more tachs, they both worked as i tested both in the garage.
So I go for a drive seems to work.....Then DEAD. I think it died right after WOT run.
any ideas what is killing them? and are they fixable? _________________ It was either this or a giant box of legos |
Posted: Sun May 23, 2021 10:12 am Post subject: |
A short in your wiring sending 12v to the wrong place? _________________ Toofah King Bad
MikeDanger
Posted: Sun May 23, 2021 10:14 am Post subject: |
| Rasta Monsta wrote: | | A short in your wiring sending 12v to the wrong place? |
could you elaborate? _________________ It was either this or a giant box of legos |
MikeDanger
Posted: Fri May 28, 2021 3:05 pm Post subject: |
SO: the problem was the Signal and +12v wires were swapped.
FYI
GREEN= Signal wire
BLACK= +12v wire _________________ It was either this or a giant box of legos |
Posted: Fri May 28, 2021 10:37 pm Post subject: |
| MikeDanger wrote: | | could you elaborate? |
Yes, see post by MikeDanger, above.
