gml
Joined: 04 Mar 2021 Posts: 133 Location: Ontario Canada
Posted: Thu May 13, 2021 1:03 pm Post subject: Fuel tank is out: should I change the hoses ASAP? |
Hey all, thanks in part to your helpful advice I have removed the fuel tank on my 82 NA. Now that I've made it this far I feel less urgency about replacing things because I realize nothing is all that inaccessible. The in-tank pump might still work and if not as I recall it was still accessible even with the transmission back in.
But there's a braided hose that was clamped to the tank itself. That seems impossible to replace without taking the tank out again. All the hoses actually seem tough to get to with the tank all in. Would it be foolish to re-use all the fuel hoses? I also thought I read something about lock or crush washers needing to be replaced on the fuel tank mounts.
Finally — I have a rusty, patched-up-but-still-leaking fuel tank. Any recommended course of action? I think I'll just give it away for free and hope it helps someone local. _________________ George
1982 924 NA 5-speed |
!tom
Posted: Thu May 13, 2021 4:02 pm Post subject: |
Standard advice is to replace any perishable parts when they are exposed during maintenance activities, in particular those that appear to be more than a few years old.
Hoses certainly qualify.
It's unlikely you'll regret replacing a hose, and likely you'll regret not replacing one. _________________ 78 924 NA
5-lug |
gml
Posted: Thu May 13, 2021 11:32 pm Post subject: |
That was my sense... hope I can get replacements pretty quickly. Can anyone help me find the hose diameters required for the fuel filler/fuel tank connections? _________________ George
gml
Posted: Fri May 14, 2021 1:12 am Post subject: |
This is the best I could do, found a few part numbers on Pelican. Not sure about the rest of it though. Any other hoses with inner diameter values would be helpful!
80-85 catalog Illustration 201-05
16 477 201 159 C Breather hose -81 I think -81 means this is for pre-81 models? not for me
16 944 201 159 01 Breather hose 82- This one seems important with the bend
22 477 201 189 Breather hose 81 1
- N 020 359 1 Hose 81 15 X 2,5
80-85 catalog Illustration 201-01
2 ???
6 x 2 N 020 363 1
16 477 201 393 C
18 944 201 449 00
22 N 020 362 1 Hose 15 X 2,5[/i] _________________ George
