924 Wheel Thread - Please Contribute
Goto page 1, 2, 3 ... 16, 17, 18  Next
PostPosted: Thu Feb 01, 2007 5:48 am    Post subject: 924 Wheel Thread - Please Contribute Reply with quote
Let's put up some pics/specs of wheels we are using. Once we have a little DB going, it may get moved over to the FAQ.
Please include offset, tire sizes, and mods/spacers needed.
* PLEASE NO O/T POSTS *
Many thanks,
rasta
*Courtesy of EndWrench, offset calculator, and tire size calculator*
PostPosted: Thu Feb 01, 2007 5:57 am    Post subject: Reply with quote
FRONT WHEEL: Porsche Design 90, 6x16, 52mm Offset
FRONT TIRE: P205/55R16 89V (Yokohama Avid V4s)
FRONT MODS/SPACERS: Fender lip factory rolled, no other mods
REAR WHEEL: Porsche Design 90, 8x16, 52 MM Offset
REAR TIRE: P225/50R16 91V (Yokohama Avid V4s)
REAR MODS/SPACERS: Factory Spacer. Fender lip rolled with channel lock pliers and a wood block (not needed at US ride height, but once car was lowered, rubbing was likely).
Luddite PS: Pic above is thumbnail, click for larger view.
Neil924
PostPosted: Thu Feb 01, 2007 8:11 am    Post subject: Reply with quote
Your picture doesn't show the wheels very well.
I haven't been able to find these wheels anywhere else on this planet. I love them and think they suit the car perfectly.
Front wheels are 9 inch wide Ronal R10 Turbo's
Rear wheels are 10 inch wide Ronal R10 Turbo's
Front tires are 225/50/15 BF Goodrich G Force as are the new set
Rear tires are 245/50/15 BF Goodrich Comp T/A the new set are 245/50/15 Dunlop SP 8000's.
As for offsets and modifications. I don't know and don't care as the fenders are wide/ big enough to hold these wheels and tires... just barely.
CBass
PostPosted: Thu Feb 01, 2007 12:58 pm    Post subject: Reply with quote
Trying to locate 4 centres of these in 5x130, I know some VW guys that make spun rim halves for them so I can make a set of optimum offset wheels.
-nick
PostPosted: Fri Feb 02, 2007 4:52 am    Post subject: Reply with quote
Rasta is a copycat - although he managed to pull it off pretty well
Note: car is lowered ~1" with Weltmeister 200lb front springs and rear camber eccentric
Summer tires/wheels -
Front:
205/55/16 Bridgestone Potenza Re730
16x6" Design 90 52mm offset
Stock rolled fender lip
Rear:
225/50/16 Re730
16x8" Design 90 52mm offset
Stock 21mm spacer & Rolled fender lips (left tire rubbed before rolling)
Winter/Cold weather tires/wheels -
Front/Rear:
205/55/16 Kumho HP4 716
Stock rear spacers
Summer wheels-
1980 931S
1991 964 C4 Cabriolet
PostPosted: Fri Feb 02, 2007 3:22 pm    Post subject: Reply with quote
No spacers, no mods, just bolted them on.
http://im1.shutterfly.com/procserv/47b5db37b3127cce91f1b94e258800000026108AZuGrlozZtE
http://im1.shutterfly.com/procserv/47b3db05b3127cce9cba462368c800000026108AZuGrlozZtE
http://im1.shutterfly.com/procserv/47b3db05b3127cce9cba462168ca00000026108AZuGrlozZtE
20v924
PostPosted: Sun Feb 04, 2007 1:41 pm    Post subject: Reply with quote
Hey Paul,
Were you able to use the 9's in the rear. I bought a set of these wheels and have yet to mount them. I was going to use the factory 930 25mm rear spacers. How much space do you have between the sping plate and the tire. they will appear onthe club sport 20v later in the spring.Yours looks good in white.
A person is smart. People are stupid
PostPosted: Mon Feb 05, 2007 4:48 am    Post subject: Reply with quote
7x17" wheels with 55 offset on all 4. Larger tires/wheels on the rear cause understeer.
These are stock 993 FRONT wheels on a 924S.
dpw928
PostPosted: Mon Feb 05, 2007 4:58 am    Post subject: Reply with quote
928 16x7 62mm(?) offset phonedials.
http://new.photos.yahoo.com/dpw928@sbcglobal.net/album/576460762336149588/photo/294928803511797967/2
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
20v924
PostPosted: Mon Feb 05, 2007 5:21 am    Post subject: Reply with quote
Not bad, How about the six spoke three piece from an Audi 90 coupe Quattro. I have been debating......993 cups...........Audi Speedlines..........993 cups.......
StienbargerR
PostPosted: Tue Feb 20, 2007 9:33 am    Post subject: Reply with quote
Here are some Focus Rims. I'm pretty sure they fit, and they look pretty nice, but not to flashy
Ryan
1978 924 NA
-250lb lowering springs, Euro Pistons
PostPosted: Wed Aug 22, 2007 6:17 am    Post subject: Reply with quote
Hmmm, someone's hounded me to contribute and I was going to say "I do not know",
but then just found some old notes -
late 931 OE "flat wheels", (aka- garbage can lids, sewer hole covers, 928 wheels, etc.)
part no.: 477.601.026B FCO
size - 6Jx16
backspace - 5-19/32" (142mm)
offset - 52.3mm
911 "Fuchs wheels" (aka- Fuchs 5-spoke, or just 5-spoke wheels)
part no.: 911.361.020 FCO
size - 6Jx16
backspace - 4-7/8" (125mm)
offset - 36mm
(The Fuchs (say- "Fooks", please ) stick out 16mm more than the OE wheels, and the tires on Fuchs wheels
rubbed both front and rear-left fenders on bumps and turns until the suspension was
upgraded (including thicker front stab.bar, added rear stab.bar, 220lb. standard height
front springs, and JCW rear shock helper springs) and thinner spacing is used on the rear-left
when the Fuchs (with spring-summer-fall tires) are installed.)
PostPosted: Wed Aug 22, 2007 10:57 pm    Post subject: Reply with quote
Black car second from left...
BBS rims
front 7" Rear 8"
tyres front 205/60/15
tyres rear 225/55/15
no spacers - 5 stud 931 turbo vented rotors
944 rear flares
GT front quarters
J1NX3D
PostPosted: Thu Aug 23, 2007 7:07 am    Post subject: Reply with quote
they used to have a small cult following in nz for older japanese car drifting. they're not as common now but they used to be reasonably priced. my mate had them on his '82 celica.
'86 944
PostPosted: Wed Oct 10, 2007 1:46 pm    Post subject: Reply with quote
Front, 16x7 turbo phone dial with 205 50 16.
Rear, 16x8 turbo phone dial with 225 45 16.
Offsets 23.3 mm
No spacers.
Will be running the following tires shortly.
Yokohama 245 45 16 Rear
Yokohama 225 50 16 Front
[img][/img]
See? No spacer.
[img][/img]
Page 1 of 18
