79porsche
Joined: 12 Feb 2006 Posts: 36 Location: Greensboro, North Carolina
Posted: Wed Apr 25, 2007 3:03 pm Post subject: Alternator belt wearing rapidly |
I just put on new belts not long ago and my altenator belt is wearing. After looking at the alignment of the pulleys for the altenator belt....I noticed that the altenator is not sitting straight. What wears that would let the altenator's position shift? _________________ 1979 Porsche 924 N/A |
Posted: Wed Apr 25, 2007 4:19 pm Post subject: |
upper bushings... and lower rubber mount breaks...
Mike924
Posted: Wed Apr 25, 2007 5:05 pm Post subject: |
If the lower rubber mount has gone, I'd advise replacing it with a home-made solid bracket. It'll make the adjusting the belt tension a whole lot easier.
If your upper bushes are rubber, replace then with ppoly bushes. I believe Ozzie found some Nissan poly suspension parts that are a good fit! _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Mike924
Posted: Wed Apr 25, 2007 5:09 pm Post subject: |
Opps! My mistake: it was Toyota Land Cruiser _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Thu Apr 26, 2007 12:57 am Post subject: |
Leadfoot forgot to mention his economic alternative:
| Quote: | Fo bushings I cheated and used skateboard truck bushings... 8$ for a pack of 4 in firm or hard.
Urethane too!
Or porsche part:059 903 263A bush For top mounts.
Roger |
das push
Joined: 27 Oct 2005 Posts: 53 Location: cincy, oh, usa
Posted: Thu Apr 26, 2007 1:52 pm Post subject: |
Check to make sure the top front mount is on in the proper direction. If you have replaced the water pump, that bracket had to be removed. If put on backwards it will move the pulley about an 1/8 to a 1/4 of an inch out of alignmet.
Ask me how I know? After 2 belts in about 5k miles I realized my mistake. Whoops. _________________ 1982 924 NA 85K owned since 1992
82 nicknamed das push"the push"by my kids.
lots of electrical problems 1st yr of owner ship! |
seanski44
Joined: 13 Mar 2006 Posts: 532 Location: Nottingham UK
Posted: Fri Apr 27, 2007 8:01 pm Post subject: |
| das push wrote: | Check to make sure the top front mount is on in the proper direction. If you have replaced the water pump, that bracket had to be removed. If put on backwards it will move the pulley about an 1/8 to a 1/4 of an inch out of alignmet.
Ask me how I know? After 2 belts in about 5k miles I realized my mistake. Whoops. |
that could have been why my belt had a number of snaps in a short space of time - I took to carrying a spare! - also had issues with the correct length (all that palaver about different alternator pulley sizes!) _________________ 1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD |
79porsche
Posted: Fri May 04, 2007 4:04 am Post subject: |
The souce of the problem is that there's two rubber covered mounts that hold the top of the alternator and the front mount rubber is completely missing. The mount on the bottom of the alternator consists of a large rubber chunk and it looks ok but it's not very firm...but it's not broken.
I don't see how the upper mounts can be fabricated.....they have a metal core that's the size of the bolt...which is covered in rubber...and the outside of the rubber slips into the metal bracket. The lower mount seems like it could be fabricated. I guess I need to try to find some factory replacement mounts for the top. _________________ 1979 Porsche 924 N/A |
Ozzie
Posted: Fri May 04, 2007 7:29 am Post subject: |
The urethane mounts I got have a steel inner spacer tube.
Get 4 in a pack- you only need three. $26Au.
Steeny has the part no- I sent him the packet with 2 in it. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
79porsche
Posted: Tue May 08, 2007 3:02 am Post subject: A/C compresser rubber mount |
Seems that my A/C compressor is also not lined-up correctly....and the rubber in the mount might be the problem. Where do I find the rubber bushing that goes in the a/c mount? All the rubber is dead on this car after 28 years. _________________ 1979 Porsche 924 N/A |
79porsche
Posted: Tue May 08, 2007 3:08 am Post subject: A/C compresser rubber mount |
Posted: Tue May 08, 2007 3:46 am Post subject: |
Having both the RHD and LHD alternator mounting brackets to compare, I notice that the rubber bushes are different between the US and OZ.
The RHD front bush is cylindrical and sits in a tube section whereas the USA one is a grommet shape. They both have an internal metal sleve.
It is likely that the RHD alternatives wont be a good fit on LHD. This is probably one instance where the genuine part is most cost effective.
Incidently, there is a 4mm spacer behind the waterpump pulley on both versions. LHD has the pulley moumted so that the belt runs behind the pump flange while RHD flips the pulley forward.
Roger |
Posted: Tue May 08, 2007 3:47 am Post subject: |
Roger |
Posted: Tue May 08, 2007 3:48 am Post subject: |
Roger |
Posted: Tue May 08, 2007 3:51 am Post subject: |
Roger |
