door seal fitment issue
mattaebersold
PostPosted: Tue Oct 06, 2020 3:10 pm    Post subject: door seal fitment issue Reply with quote
I got the door seals for the 924/944 from pelican. Overall, the seals seem to fit fine, but there's a really large lip around the top that looks to be quite large (so much so that the seal is preventing the door from shutting at the A pillar. I *think* the solution is to just cut the excess off, but I wanted to ask first before just doing that.
Check out this gallery:
https://imgur.com/gallery/ZfRNMF4
PARTSTASH: www.partstash.com
1980 931
1991 Japanese Classic Mini
2005 Touareg V8
2006 530xi Wagon
Goldwolf
PostPosted: Wed Oct 07, 2020 7:38 am    Post subject: Reply with quote
IDK, what would you cut? Seems like the bead needs to be stuffed in more. I have not done this myself. What does the other side look like? The factory fitment?
1981 Weissach Edition #179
Savethe924.com
PostPosted: Wed Oct 07, 2020 6:04 pm    Post subject: Reply with quote
Looks pretty ok, make sure its really seated. The newer multi lip door seals do make the door a bit harder to close, but also makes the car quieter with less wind noise. I didn't cut mine anywhere.
