felix83
Posted: Fri Mar 20, 2020 4:08 pm Post subject: Indicator and hazard problems |
My indicators don't work, nothing happens when flicking the switch. If i turn them on with everything off, the parking lights come on on the corresponding side, as they should. I've cleaned up the stalk assembly itself, the fuse holders (replacing all fuses for good measure) and the grounding points under the dash.
My hazards do work, however they seem to have developed an intermittent arrythmia:
https://www.youtube.com/watch?v=J1qGk7IsCb4
Could this be indicative of the flasher relay starting to go bad?
The thing is, after cleaning the stalk switch and the fuse box, the indicators worked fine. The problem appeared after cleaning the grounding points and fixing a broken connector on one of the cables. _________________ Felix
'77 924
'82 911 SC
Instagram: @orebro.classics | @924.resurrection |
K-Roll931
Joined: 08 Jul 2017 Posts: 76 Location: Southfield, MI
Posted: Sat Mar 21, 2020 3:52 am Post subject: |
That's odd, my car has the opposite issue: Indicators work, and the hazards don't. They haven't worked in at least a year. _________________ '80 931 M471 - Dolomite Gray -> Monaco Blue |
felix83
Posted: Sat Mar 21, 2020 4:55 am Post subject: |
| K-Roll931 wrote: | | That's odd, my car has the opposite issue: Indicators work, and the hazards don't. They haven't worked in at least a year. |
Ah, the joy of old cars. Have you checked the hazard switch? _________________ Felix
'77 924
'82 911 SC
K-Roll931
Posted: Sat Mar 21, 2020 10:16 am Post subject: |
| felix83 wrote: | | K-Roll931 wrote: | | That's odd, my car has the opposite issue: Indicators work, and the hazards don't. They haven't worked in at least a year. |
Ah, the joy of old cars. Have you checked the hazard switch? |
I replaced it, and the fuse. I might've changed the relay or flasher (whichever its called), can't remember... There was no change regardless. _________________ '80 931 M471 - Dolomite Gray -> Monaco Blue |
felix83
Posted: Sun Mar 22, 2020 8:26 am Post subject: |
In my case, it was the stalk itself. Despite my attempts to clean it, it still ha a bad connection. I've dismantled it and will try fixing it before ordering a new one. _________________ Felix
'77 924
'82 911 SC
K-Roll931
Posted: Sun Mar 22, 2020 10:06 am Post subject: |
| felix83 wrote: | | In my case, it was the stalk itself. Despite my attempts to clean it, it still ha a bad connection. I've dismantled it and will try fixing it before ordering a new one. |
I forgot about that! I changed that too with no change other than a clean and shiny stalk. I'll have to replace that flasher/relay and report back on that sometime. _________________ '80 931 M471 - Dolomite Gray -> Monaco Blue |
felix83
Posted: Sun Mar 22, 2020 5:15 pm Post subject: |
| K-Roll931 wrote: | | felix83 wrote: | | In my case, it was the stalk itself. Despite my attempts to clean it, it still ha a bad connection. I've dismantled it and will try fixing it before ordering a new one. |
I forgot about that! I changed that too with no change other than a clean and shiny stalk. I'll have to replace that flasher/relay and report back on that sometime. |
Since the hazards and indicators use the same flasher, I don't think a bad relay should cause one to stop working and not the other. I'd inspect the hazard switch socket for damage, which could explain your issue. The hazard switch is the big thing marked with E3.
'77 924
'82 911 SC
