Raceboy
Posted: Fri May 13, 2016 11:09 pm Post subject: 924 Carrera GTS replica tach/boost gauge |
Made 924 Carrera GTS replica tach/boost gauge out of 924S/944 tach with MPG gauge. Porsche also used same hardware, just different electronics and faceplate. I had the custom backround made and printed onto UV resistant matte surface. Later may do it properly with silkscreen print.
I used 911 speedo needle (it is longer on the opposite side and matches 924S MPG gauge needle better than original needle).
Click for a photo: https://scontent-arn2-1.xx.fbcdn.net/v/t1.0-9/13151995_1034961566582857_957268573368076216_n.jpg?oh=dcef919a7964e882105f17f30cd66cb9&oe=57E6998D _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Joined: 01 Oct 2004 Posts: 15544 Location: Woodstock IL
Posted: Fri May 13, 2016 11:10 pm Post subject: |
That is *way* cool!
How did you do the boost sensing part? _________________ erstwhile owner of just about every 924 variant ever made |
Raceboy
Posted: Fri May 13, 2016 11:12 pm Post subject: |
I left it like it is, VEMS is controlling the needle. But lot is ahead, I want to get it working with original MPG hardware, last resort is to use separate 924 tach circuitry outside of the tach housing (bulky and not so elegant solution). _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Raceboy
Posted: Fri May 13, 2016 11:39 pm Post subject: |
Brilliant, Peep. I want one! _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sat May 14, 2016 1:03 am Post subject: |
Way cool, i'd love one like that but to work without VEMS
I made a speedo that fits inside the 924 dash and looks like the 924 one but uses the 944 gearbox sensor instead.
Was planning to use that early tacho to try to fit a boost gauge and do a GTS replica tacho but you beat me to it
https://goo.gl/photos/yQFjASpwXLRPv6Vx9 _________________ https://www.the924.com |
Joined: 02 Nov 2002 Posts: 9489 Location: Southeast Wisconsin
Posted: Sat May 14, 2016 1:01 pm Post subject: |
Glad you got it to work, it's been a year since you received it, I was beginning to wonder... _________________ White 87 924S "Ghost"
Raceboy
Posted: Sat May 14, 2016 5:31 pm Post subject: |
I focused on it again about a month ago after I had other priorities during winter
Thanks Paul! _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
WEASEL149
Posted: Mon May 16, 2016 7:42 am Post subject: |
Very cool!  _________________ 1979 UK 932 |
Joined: 23 Jul 2007 Posts: 1075 Location: The Netherlands
Posted: Mon May 16, 2016 3:59 pm Post subject: |
Great, good work! _________________ 937 trackday car
Magnus
Posted: Sat May 28, 2016 4:49 pm Post subject: |
Very nice!!
Do you know how to modify the 924 tach to work with a Link ecu, beeing a high lewel tach it doesnt work for me...
 _________________ 931 -81 20vt Restomod build in progress... |
Raceboy
Posted: Sun May 29, 2016 5:52 pm Post subject: |
I use regular low level output which just has 1k pullup to 12v, it is already built inside ECU.
You can just use some 1k resistor and connect it between tach wire and 12v, should work. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
gegge
Posted: Mon May 30, 2016 7:47 pm Post subject: |
Where did you get the tachodial made?
http://www.heiler-tachodesign.de
or
http://neutec-tacho-design.de/ _________________ Carl Fredrik Torkildsen
Raceboy
Posted: Wed Jun 01, 2016 5:28 pm Post subject: |
My good friend designed and drawed it (he is a designer my profession), I just gave him 924S tach for dimensions and sent GTS tach photo and purchased the font used on these tachs (that cost ~20 euros).
When the vector drawing was finished I contacted another friend of mine who works in advertising company and she printed the dials on matte UV resistant sticker.
I will probably make a new set with a bit smaller numbers and when I am satisfied maybe will print it on the spare 944 tach face in silkscreen print like original. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Posted: Sun Jan 29, 2017 8:48 am Post subject: |
Pix missing...raceboy, can you fix the links? _________________ erstwhile owner of just about every 924 variant ever made |
