Bad fan switch?
Mitragorz
PostPosted: Tue Aug 27, 2019 6:06 am    Post subject: Bad fan switch? Reply with quote
I just bled my coolant system after my reservoir crapped the bed.
Got a nice stream out of the bleeder. I bled it twice, letting the car cool down in between.
I noticed that my fans didn't come on at all. I cleaned the connections on the wires and on the switch. When I jump the wires together, the fan comes on when I turn on the ignition. So obviously the relay is good and wiring is good.
Should the fan have come on while bleeding, or did it not run long enough?
Also, when I jumped the wires only one fan came on (passenger side). I'm guessing there's another switch somewhere? I'm looking at the one at the top of the rad, on the driver side.
1980 924 N/A
Ozzie
PostPosted: Tue Aug 27, 2019 6:49 am    Post subject: Reply with quote
do you have a/c?
Its AUTO and its BLACK
Montego Black on black/red
Mitragorz
PostPosted: Tue Aug 27, 2019 7:01 am    Post subject: Reply with quote
Ozzie wrote:
do you have a/c?
Yes, non-functioning factory air.
1980 924 N/A
Mitragorz
PostPosted: Tue Aug 27, 2019 7:05 am    Post subject: Reply with quote
Well it’s working. I’m currently flushing the coolant, and lo and behold the fan cam on shortly after the the bleeder started sputtering.
Only the passenger side fan, though. For now.
Edit: once the fan came on, the bleeder stopped sputtering. I unplugged it and the bubbling started again, so I guess the fan is doing it’s job!
1980 924 N/A
PostPosted: Tue Aug 27, 2019 9:46 pm    Post subject: Reply with quote
Yeah, reason Ozzie asked is that with factory AC the second fan is powered via the AC relays... so unfortunately they need to be working to get both fans on.
Of course, if you plan to remove the AC, you could jumper them...
