Warmup regulator removal
Itsarhythmcar
PostPosted: Thu Jul 18, 2019 2:28 pm    Post subject: Warmup regulator removal Reply with quote
Are there any suggestions for removing the warmup regulator from a n/a 924? I’m not as young as I used to be and my hands can’t get to the bolt on the underside. Plus my innovation with tools appears to be lacking.
1980 924 base
1995 Miata
1999 Isuzu Trooper
2008 Mazdaspeed 3
PostPosted: Thu Jul 18, 2019 10:37 pm    Post subject: Reply with quote
For sure, remove the ignition coil.
Then I recommend a short allen key bit with flex-head ratchet:
https://smile.amazon.com/Titan-TIT16112-Metric-Hex-Piece/dp/B0043C55AG/ref=sr_1_31?keywords=titan+allen+key+socket+set&qid=1563453390&s=gateway&sr=8-31
Found those at the local auto parts store, quite inexpensive but good, very useful. Much easier for this stuff than actual allen keys.
Itsarhythmcar
PostPosted: Tue Jul 23, 2019 2:36 am    Post subject: Reply with quote
Thank you for the advice. I found some similar tools at the parts store. I’ll be under the hood next weekend.
1980 924 base
1995 Miata
1999 Isuzu Trooper
2008 Mazdaspeed 3
