79 2.0 NA front calipers 4 Bolt
Schwami
PostPosted: Sun Mar 24, 2019 6:08 am    Post subject: 79 2.0 NA front calipers 4 Bolt Reply with quote
Doing some spring refreshing and I broke off a bleeder screw on the front calipers. Since I am not going to be driving for a while, I'm looking for a ideas that will get me rolling (stopping)again.
Being a thrifty porsche driver, I am looking for replacement rebuilt calipers or rebuild kits.
I have an other set of rebuildable calipers
I have stuff to trade from other 79 NA. plural
All ideas are worthy of consideration.
Thanks Crew
1979 924 Diamant Zweischicht.
Serial # 9249201031
XG 309 543 engine code.
2012 Golf Sportwagon TDI
PostPosted: Sun Mar 24, 2019 6:16 am    Post subject: Reply with quote
drill out and replace the screw?
Schwami
PostPosted: Sun Mar 24, 2019 6:35 am    Post subject: Reply with quote
not sure that is going to work out.... I lubed and heated the caliper and screw prior to breaking it of.... worth a shot though.... i think that the other side is going to suffer the same fate too
Serial # 9249201031
Schwami
PostPosted: Sun Mar 24, 2019 10:11 am    Post subject: Reply with quote
Well, I ran out of daylight BUT, I used the extra parts and cobbled it all back together.... 10YO son helped pump them and they are HARD!
I'll do a test drive in the morning.
Meanwhile, I'm getting a few rebuild kits and next is the driver front. rears are already done.
Its been a couple years and I plan on doing the water hoses and trans oil.
Serial # 9249201031
PostPosted: Sun Mar 24, 2019 12:32 pm    Post subject: Reply with quote
Start off by soaking them with penetrating oil for a couple of days. What we did in the old days is to touch the offending bolt with an arc welder. The current seemed to break steel loose from the cast iron.
Mike
'67 MG Midget Dp
