cleaning gas tank
Cole Thomas
PostPosted: Fri Mar 22, 2019 12:55 pm    Post subject: cleaning gas tank Reply with quote
I have a 1982 924 2.0 NA that hasn't been on the road since about 1991. There is some sediment in the gas tank. What is the best way to get it as clean as possible without removing the tank. Thank you in advance for the responses.
1982 Porsche 924 NA project
PostPosted: Sat Mar 23, 2019 2:38 am    Post subject: Reply with quote
Drain it at the outlet. Rag and screwdriver can get quite a bit out after the pickup fitting is removed. You can then carefully pour a bit more through while the bottom is open.
